Team Associated Factory Team RC10R5
#301
Finally, the wide R5 ready-to-run with PF Peugeot P905B HD body I took from my RC10L2...
The car is almost fully balanced without balancing weigt, I only had to add 7.5gr to the right side due to the fact that I determined the battery position using a TC Spec ESC along with a Spektrum SR3500 micro receiver. The now finally used GM Genius 120 ESC with the Spektrum SR300 receiver seem to put up this 7.5gr more weight.
The motor is a Speed Passion Comp 2.0 4.5T laying around since last year...
I'm really looking forward to the roll out...i'll keep you updated...
Cheers Andy
Cheers Andy
#302
Rear Axle Vibration
Question for all you pan gurus. I notice that when I hold my car off the ground, and give it the throttle, somewhere between 30% and 60% throttle the rear shaft generates a bit of a vibration and resulting noise. I first noticed the sound watching all the WGT cars go down the back straight... and saying to myself "man.. all the pan cars make a strange grinding/wirring noise as they take off". Well.. mine does the same thing.
What causes this? Is there any way to dial it out?
#303
Tire balance or out of round?
#304
Are you asking me if that is the issue? Cause I don't know... that is why I asked. Every car that goes by at my track makes the same noise under throttle... they aren't soft and quiet like the drive of a typical TC.
Do you have to balance your wheels on a pan car? Cause mine are just cut to 58mm and I ran them there.
#305
#306
Since we don't have any rules (and no races) for Pro10 wide cars in Switzerland, the 1200gr rule is not of any importance for us here...
1. worn out axle bearings
2. worn out axle on the spots, where the bearings are sitting
3. bent hubs (right and/or left side) due to a heavy crash
4. bent axle due to a heavy crash
5. crooked rims due to heavy crash
6. worn out rear ride height spacers (bearing holders)
1 and 2 usually can happen due to crash or when the rear axle ride height spacers (bearing holders) have to much of play (see 6), the axle gets worn out and you get the vibration and noise at high revs.
#307
Possible causes are:
#308
Hey guys, what is the best way to clean the jaco spec foam tires after a day of racing? Or do you even need to clean them at all? All i know, is now my house reeks of paragon from the foam tires on my 10r5. I washed the tires in teh sink using only warm water, but they still stink something feirce.
Clean with simplegreen, rinse with water? Live with the stink? Only keep foam cars in the garage? Thanks for any tips.
#309
#310
