Old 06-09-2009, 02:54 PM   #271
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by andrewdoherty View Post
4 cell NiMh or LiPo? In our medium carpet track I am running full timing (26*) and a 66 mm rollout with a LPF 2.0 and a SP 13.5 with 1 cell LiPo.
Im going to be running the factory spur, I have 36 through 43 tooth pinions, 13.5 redlin with an RS... 1s lipo. I need to practice this whole "roll out" thing. Its all very foreign to an old school sedan guy.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-09-2009, 03:57 PM   #272
AE-Reedy
Not positive what gearing will be like with the 1s, I did try running with a 40/96. It seemed ok, laptimes similar to maybe even a little faster than 4cell laps. That was mostly down to the grip on the track. I think a 40 was the biggest I could fit with the 96 spur. If you run larger tires you won't need as big a pinion though.
Sean Cochran is offline   Reply With Quote
Old 06-10-2009, 12:53 PM   #273
LOW ET's Avatar
Trader Rating: 97 (100%+)
for those using the inline steering blocks, do you use the set screw that goes in the axle to lock the block on the kingpin?
LOW ET is offline   Reply With Quote
Old 06-10-2009, 01:56 PM   #274
AE-Reedy
You can if you want but I don't normally use it.
Old 06-13-2009, 11:11 PM   #275
Trader Rating: 23 (100%+)
Are there in companies making scale decals for the bodies used in this class?
bmcallister is offline   Reply With Quote
Old 06-14-2009, 04:03 AM   #276
V12
V12's Avatar
Someone tried running a laydown servo?
V12 is offline   Reply With Quote
Old 06-16-2009, 06:57 AM   #277
I am looking for a used 10r5 in good shape if anyone has one for sale. Email me at [email protected]
Old 06-16-2009, 07:18 AM   #278
Ok guys I know this is an associated thread and hate to debate on here. I have always been an associated fan, and currently own a 12r5 and a tc5f. I am wanting to hear opinions on how the crc genx10 and the 10r5 compare in your opinion. I have looked at both cars and currently up in the air on which to go with. Lets hear your honest opinions on performace and preference.
Thanks!
Old 06-16-2009, 08:13 AM   #279
AndiF's Avatar
I own and drive both, the GenX10 and the RC10R5, I love both the cars but frankly speaking, the GenX10 is easier to drive and goes like hell already out of the box while the RC10R5 needs more set up efforts to get it working. But once you get it there, it's as fast and efficient as the CRC.
On the CRC I like the specific 10th scale layout of the main chassis against the blown up 12th scale chassis of the R5 which in my opinion is the reason why it does not perform on the same level right out of the box as the CRC does...
On the R5, I love it's simplicity and style. Very easy on maintenance. Great shocks...and high performance once you get it right with the setup.
Just my personal opinion...
Cheers,
Andy
Team Durango Switzerland - Corally - CRC - IRS - Team Associated
AndiF is offline   Reply With Quote
Old 06-16-2009, 08:53 AM   #280
Super Moderator
Cheers,
Andy
Wow... almost the exact opposite I have heard from everybody else in a comparison between teh two cars. Everybody I have spoken to says that the 10r5 will blister down the track right out of the box, and the CRC takes a bunch of tweaking and tuning to get it to perform.
- RCSpecialties -
Old 06-16-2009, 08:55 AM   #281
Super Moderator
Wait... how did you run 40/96? The largest pinion I could fit into the pod with the stock spur, was 36tooth. The motor was literally as far forward as it could go and I JUST BARELY got enough tooth spacing to get it to work. A 37 would not of fit in my car...
- RCSpecialties -
Old 06-16-2009, 09:34 AM   #282
AndiF's Avatar
Maybe this depends how you run it. I'm not talking about World GT 4-Cell layout but 2s LiPo with motors down to 5.5T. Maybe this makes the difference...
However, most of the time I'm driving 2s LiPo and 13.5T in our Swiss GT class over here in Switzerland...
And as I said, it's just my personal experience and opinion...others may have different ideas and opinions...
Cheers,
Andy
Old 06-16-2009, 10:34 AM   #283
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
If you look carefully the limiting factor to moving the motor forward is not the holes in the motor plate, but the carbon fiber top and bottom plates. A little finesse with a dremel and I can fit a 76/60 (same tooth count as a 96/40) in the AE pod. I can fit more, but I just don't have the pinions to test it!
Old 06-16-2009, 03:30 PM   #284
AE-Reedy
Andrew is correct about filing the graphite plates. Motor brands also have an influence on how big a gear will fit. I use a LRP motor and it has a beveled edge on the mounting face so it doesn't interfer with the graphite plate as much.
Old 06-17-2009, 06:37 AM   #285
Appreciate the info, kepp it coming!
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
