Old 12-12-2008, 12:04 PM   #166
AE-Reedy
Originally Posted by t4mania View Post
Sean, have a setup for indoor carpet medium sized track and maybe a setup for outdoor asphalt.
For sure on the carpet just start with the kit set up, you shouldn't have to make but minor changes from there to suit you. On asphalt I don't have any experience with this car but again I would start with kit set up and go from there. The asphalt track is mostly going to depend on tires and sauces. If the grip is very low you might have to soften the rear suspension.
Sean Cochran is offline   Reply With Quote
Old 12-12-2008, 12:06 PM   #167
AE-Reedy
Originally Posted by T4-RC8 RACER77 View Post
hey sean does the team plan on doing a chassis for the rc10r5 that will take a lipo that would fit in a T4 or B4?? or a saddle pack lipo like the B44.
There hasn't been any discussion about that at this time. If something changes in the rules for the class that allows lipos I'm sure we will look into it.
Old 12-12-2008, 01:46 PM   #168
Gain Time's Avatar
Cant wait to get back to the track to test somethings out......only been two weeks and I am going through withdrawals.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 12-18-2008, 04:34 PM   #169
Default widening front end
I'm going to try widening the front track by shimming the lower a-arm (4620) out from the block #4614. I will then reset the camber. I will likely need longer steering ball cups. This will widen the car without increasing the scrub radius which happens when you shim the front axle or front wheel. I'll let you know how it works out.
I've been running front pinks on a low to medium grip tight carpet track and was traction rolling. I installed 0.020" springs and widened the front by shimming out the wheels on the front axle which helped. I'll try the lower arm shim over the holidays. This will change the camber gain a bit but we'll see. I can always shim up the top a-arm at the steering block.
Three race nights with this car so far without any problems even with lots of hits. Nothing broke yet. We're about 0.6 second off our 1/12 times. We'll get faster.
Regards,
Etienne
Tuner EM is offline   Reply With Quote
Old 12-19-2008, 11:33 AM   #170
I used to do carpet oval way back in the day (10+ yrs) and im getting back into it. i just bought my r5 and wanted to get into this new GT class and was wondering what was a good starting point on a pinion and spur setup. I have a gtb and and a 13.5. thanks for any help guys and girls.
Ken
greg dooler is offline   Reply With Quote
Old 12-19-2008, 09:27 PM   #171
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Different 13.5's like a little different gear. I would start with an 88/35 combo indoors on carpet.
Old 12-22-2008, 07:37 PM   #172
AE-Reedy
Ken
I ran 36/96 with 2.1" tires in Vegas and Cleveland. This was with LRP motor and SC, you might have to run more gear with a Novak SC.
Old 12-25-2008, 09:03 AM   #173
Jamesalex's Avatar
Questions??
Hi,
I got a RC10R5 today and was wondering what spares I would need to carry, what springs I need, if there is anywhere with some set ups and last but not least what pinion and spurs I would need being 48 or 64
Cheers in advanced
James
Jamesalex is offline   Reply With Quote
Old 01-10-2009, 04:39 PM   #174
Default Lipo & steering mod
Lipo
I moved the center shock mount over to the left by 8.5 mm which now gives enough room for a lipo. I installed the shock on the other side of the plate to keep it centered. The car is shown with a spec 2400 lipo for a spec class will be starting soon. I plan on taping the battery in place.
Team Associated Factory Team RC10R5-dsc03100.jpgTeam Associated Factory Team RC10R5-dsc03101.jpg
Steering Mod
For those of you who hit a lot of boards I found that hitting the inside corner with the wheel turn can force the wheel to get pushed past the a-arm holder nut and jam there. This also ruins tires. I installed short allen screws 3mm x 4mm (3x3 would be better) to serve as steering stops. We race on a very small tight track so there is some bumping going on. The AE RC10R5 is good so far. The front parts seem flexible as I haven't broke anything yet after lots of hitting.
Servo
I used a servo with a 35oz.in @ 6V rating on 4 cell and it didn't feel right too slow. I changed it to a stronger Futaba S9650.
Old 01-20-2009, 02:39 PM   #175
2fast4u42's Avatar
Send a message via MSN to 2fast4u42
Wink yea baby
i went 111.6 mph today with the castle creations mamba max and 9000 motor and a 3s lipo
2fast4u42 is offline   Reply With Quote
Old 01-21-2009, 12:38 PM   #176
Hi,
at the moment we are developing a LiPo conversion kit for the 10R5 here in Germany. At the moment we are still in an early stage of development as there is a bit of a problem with parts supply but I will keep you posted on this.
As the wide Pro10's are still popular over here there will be a conversion for this aswell.
If you're interested in getting one send me a PM and I will inform you when we have news about pricing and availability.
Regards
Chris
AE RC12R5
AE RC10TC5
AE RC10L2 "2008"
powered by Nosram/Reedy
speedy-932 is offline   Reply With Quote
Old 01-22-2009, 03:41 PM   #177
Default Problem with Left Hub
Hi everyone,
I've just started running my 10R5 and experienced a problem with the left hub during a regional race last weekend. No matter how hard I tightened the left hub screw the hub would always slide outwards 3-4mm by the end of the heat!
It was almost like the axle is SLIGHTLY too small for the hub or the inside radius of the hub is SLIGHTLY too large for the axle. I tried the hub that came with my kit and the hub I had bought as a spare and had the problem with both of them.
Has anybody had this issue? Any ideas on how to fix it?
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 01-22-2009, 03:51 PM   #178
check back a page or two. There were a couple ideas for a solution to that problem.
Old 01-22-2009, 03:57 PM   #179
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default hey mike
Originally Posted by Hyper_Mike View Post
Hi everyone,
Cheers,
Mike
mike try there sugestions or go to irs and get a hub from them that has 2 screws in it and your not the only one with this problem i got the hub and no more problems just hub is silver is all
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 01-22-2009, 05:57 PM   #180
Suspended
how much will everything for the car and the car cost to get running..icluding batteries, charger, no remote no power supply...
THANKS
B4 Racer1 is offline   Reply With Quote
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
