Old 11-25-2008, 06:53 PM   #136
Default Lipo in RC10R5
The AE RC10R5 can probably be easily modified for a lipo by moving the center shock mount to the left. The rear shock will still be centered if it is installed on the other side of the plate. This gives enough room for the battery as seen in white in the photo. You can see the original holes on the edge of the battery layout. Two holes will need to be drilled 9 mm to the left. This leaves enough room on the left for the electronics but may not balance out perfectly. Our local club allows lipo in 1/10 pan car on a medium size asphalt track.
Tuner EM is offline   Reply With Quote
Old 11-26-2008, 12:00 PM   #137
Gain Time's Avatar
Interesting.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 11-27-2008, 06:51 PM   #138
Default build
The build went well. The front end is much smoother after polishing the kingpin and trimming the upper a-arm eyelet slightly. I now have full motion without binding. The rear suspension is very smooth with little play. Hard to adjust the center pivot though. Track testing soon. I changed the rear spring retainers to the steel CRC ones (drilled and tapped for 3 mm) since I seen another car where the plastic ones were all twisted.
Old 11-29-2008, 08:52 PM   #139
Gain Time's Avatar
What is "Active Castor"? Does it behave like normal Castor?
Old 11-29-2008, 08:56 PM   #140
KHoff7's Avatar
Reduces castor angle as the suspension compresses.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-29-2008, 09:03 PM   #141
Gain Time's Avatar
So reducing the Active Castor would increase the initial turn?
Old 11-29-2008, 09:06 PM   #142
KHoff7's Avatar
Once the suspension is compressed after settling into the turn it will make it turn harder and feel more darty. Initial it wolnt change much. But it will make it turn harder overall.
Karl Hoffmeister
Old 11-29-2008, 09:15 PM   #143
Gain Time's Avatar
Thank you.
Old 11-30-2008, 12:53 PM   #144
Guest
Send a message via Yahoo to T4-RC8 RACER77
Questions?? Help
hi guys I need help? What type of servo do I need for the rc10r5 and brand? And does hitec make one that will fit? Any team drivers help would be great?
T4-RC8 RACER77 is offline   Reply With Quote
Old 11-30-2008, 01:34 PM   #145
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Futaba 9650 fits and works great. You can technically use any servo you'd like, but not all will fit in the servo mounts without drilling your own holes. You can also shoe-goo it down of course as well.
Old 11-30-2008, 01:37 PM   #146
Are the new BL pod parts available anywhere?
Old 11-30-2008, 08:28 PM   #147
Guest
Default thank you drew
thank u drew, whats up with the rear pod on the car?? will novak motors fit in it easy or what?? i been tring to decide which car to get. (crc gen x 10) or the rc10r5, but i think i'm going to stick with the team.
Old 12-08-2008, 12:18 AM   #148
Guest
Questions?? what the ??
hey wheres the rc10r5 guys at?
Old 12-08-2008, 05:58 AM   #149
Gain Time's Avatar
mine is broke and I am still waiting on parts to arrive.
Old 12-08-2008, 11:09 PM   #150
Guest
Default Ouch
What broke ? How does. It run,handle,I am trying to decide between crc or rc10r5
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
New Team Associated FACTORY TEAM TC3 with full BMI BLUE Graphite Chassis LOADED!!! Ron Meloni R/C Items: For Sale/Trade 6 06-26-2004 07:09 AM
Incredible Team Associated FACTORY Team 12L3 w/IRS RUG RAT conversion. LOADED!!! Ron Meloni R/C Items: For Sale/Trade 2 06-06-2004 09:15 AM
