Old 08-10-2003, 11:41 PM   #1
LeoChan's Avatar
Send a message via ICQ to LeoChan
Default Indoor Carpet ?
Indoor Carpet use which tires bester ?
about temp 25óJ
new carpet small tract many turn about 17 sec lap
I'm before used SOREX 24R,28R & 32R but oly small traction.
Thanks !
LeoChan is offline   Reply With Quote
Old 08-11-2003, 11:20 AM   #2
the trc plaid and purple compound. also, get a bottle of traction compound
ernieball is offline   Reply With Quote
Old 08-11-2003, 11:54 AM   #3
LeoChan's Avatar
What is TRC tires ?
have website ?
Proline tires bester ?
Old 08-11-2003, 12:11 PM   #4
fatdoggy's Avatar
R/C Tech Charter Subscriber
TRC plaid/purples are foam tyres. If your allowed to run foams then these are great but if your only alowed rubbers... Do you use traction compound with the sorex tyres?
fatdoggy is offline   Reply With Quote
Old 08-11-2003, 11:37 PM   #5
LeoChan's Avatar
only use rubbers tires
used fx2
Old 08-12-2003, 12:44 AM   #6
fatdoggy's Avatar
I've read about people using Sorex 24R's up front and 20R's in the rear. Get some decient compound, paragon, corally jack the gripper or alike, it sounds like your current compound isn't doing it's job. If possible heat up your tyres before you hit the track. Your sorex 24R's should hook up with some decient compound and maybe heating if needed.
Old 08-12-2003, 12:56 PM   #7
LeoChan's Avatar
But i'm have use tire warmer !
I'm touch tires only lower temp
Do you need use soft inner to take more traction ?
or can use proline tire in carpet ?
Indoor carpet track? dirtdynamics Singapore R/C Racers 0 01-23-2006 09:53 AM
Indoor Carpet Interest Rindaen Georgia Racing 6 11-06-2005 05:48 AM
New Indoor Carpet Track in MD Big D Track Locator Forum 5 11-10-2003 06:05 PM
Indoor Asphalt vs. Indoor Carpet Evoracer Electric On-Road 39 08-11-2003 06:34 PM
Indoor Carpet track in FL MdiRacing Racing Forum 2 04-10-2003 09:30 AM
