Old 08-10-2003, 10:49 PM   #1
ruftnik's Avatar
Send a message via Yahoo to ruftnik
Default best motor
i'm a newbie and wanted to have the best or a better motor. based on your experience, what can you recommend? whats the ratio of pinion gear to no. of turns of the motor.
ruftnik is offline   Reply With Quote
Old 08-10-2003, 11:16 PM   #2
NMRCDude's Avatar
Send a message via AIM to NMRCDude
First of all, are you talking about a stock motor, which is a 27 turn? Or are you talking about a modified motor (low turns)
NMRCDude is offline   Reply With Quote
Old 08-10-2003, 11:35 PM   #3
ruftnik's Avatar
sorry for the confusion, i'm talking about which brand of stock motors have the best speed and torgue and the the ratio of pinion gears to no. of turns of the motor.
Old 08-11-2003, 12:11 AM   #4
Send a message via AIM to Smartazz07
There is no ratio of # of turns to gear ratio its just therpm's of the motor that can tell you how fast it goes.
Smartazz07 is offline   Reply With Quote
Old 08-11-2003, 12:21 AM   #5
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm running Team Paradigm motors, and recommend them, very good power, and they are tweaked for racing when you get them. Try the Monster Stock based motor, and run a 7.1 final drive ratio and you'll have some good power and speed.
Old 08-11-2003, 12:48 AM   #6
ruftnik's Avatar
they said that if you change your motor you should also change your pinion gear so that you will not sacfrice the torque and topspeed. is this true?
Old 08-11-2003, 01:03 AM   #7
Cole Trickle's Avatar
Gearing rule of thumb: 3/4 down the longest straight at the track, your car should reach top end speed. If so, the car is geared correctly.
If it's a large open track, you might go one teeth higher on the pinion to get higher top-end. On a small tight technical track, you might go one teeth lower, to ensure acceleration.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-11-2003, 01:06 AM   #8
If you want to be a good driver fast, get a motor, that aint too fast !
Because a fast mator is quite hard to handle, while a sligthly slower one, will allow you to build up your driving skills faster. A good motor for this, is the Peak Panther (or a similar one).
Later on, you can get a faster stock motor.
Old 08-11-2003, 01:25 AM   #9
ruftnik's Avatar
thanks bro.
Old 08-11-2003, 07:56 PM   #10
rcshark's Avatar
Send a message via Yahoo to rcshark
i have three boys of my own that i am teaching and watching they do well when i tell them to "slow down and they will get there faster" I have also use that for my self. how ever there is always some one faster.
rcshark is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
