Old 07-08-2009, 04:57 PM   #16
Smile Novak timing
kudders I faced the same problem, I wasn't sure where the motors factory timing should be!
Novak sent me these images so I thought id share them (See attached).
Hope that helps!
Cheers,
Toby.
Novak GTB & 10.5 Brushless Timing Question-advanced.jpg   Novak GTB & 10.5 Brushless Timing Question-reduced.jpg   Novak GTB & 10.5 Brushless Timing Question-factory.jpg
tobydeh is offline   Reply With Quote
Old 07-08-2009, 05:30 PM   #17
espresso1967's Avatar
Trader Rating: 18 (100%+)
Thanks for that info thought are you turning it clock wise or counter? I was advised to change my 10.5 to 12, what does this mean or how far to turn it to get my timing to 12?
Hope that helps!
Cheers,
Toby.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 07-08-2009, 06:52 PM   #18
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hope that helps!
Cheers,
Toby.
Sorry Toby im new to electrics and feel like an idiot right now, i can see no differences between the 3 pics lol !!, can you explain ?
thanks,
Pat
Tabushi is offline   Reply With Quote
Old 07-08-2009, 09:32 PM   #19
thanks,
Pat
Look really closely to the position of the notches on the blue ring in comparison to the screw on the bottom of the motor. You can see its in different locations in all 3 pictures.
If you want more information about how timing effects a motor, look into the HomeMade dyno, has some really nice graphs.
Shawn.
Shawn68z is offline   Reply With Quote
Old 07-10-2009, 12:05 PM   #20
So how does not determine a timing of 12?
Old 07-11-2009, 01:46 AM   #21
Unfortunately there is no real way of telling on the Novak SS motors.
Old 10-19-2009, 08:35 PM   #22
Airflow's Avatar
Novak Pre-Ballistic Motors
Advance timing --- turn the timing ring anti-clockwise
On the new Ballistic motors
Advance timing --- turn the end cap CLOCKWISE
Im really confused. Can some expert explain this?
Airflow is offline   Reply With Quote
Old 10-19-2009, 09:37 PM   #23
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
do you have a ballistic? if so mine is still counterclockwise for advancing...`youre moving the end cap.. check your local track im sure someone have novak brushless.... and ask them.
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 10-19-2009, 09:57 PM   #24
Airflow's Avatar
I still have the old EX motors and Im planning to buy Ballistic motors
for 2010. Ive downloaded the Ballistic Motor Timing Guide and it clearly
says that to have advance timing, the end cap should be rotated
clockwise. http://www.teamnovak.com/tech_info/i...tes/index.html or
To adjust the Ballistic motor to this recommended 5 degree timing setting:
1. Loosen the three 1.5 mm hex‐head screws on the back timing cap of the motor.
2. Turn the end cap clockwise until the stationary notch on the end bell lines up to the
edge of the label.
3. Re‐tighten the three 1.5 mm hex‐head screws in a circular pattern to ensure that they
are evenly tightened.
A visual diagram or illustration would help.
Old 10-19-2009, 10:09 PM   #25
pinggoy's Avatar
TAMIYA TRF416X
Old 10-19-2009, 10:25 PM   #26
pinggoy's Avatar
Airflow,
you forgot to clearly read this
NOTE: If you adjust the timing to lower than the pre‐set factory setting of 30 degrees, the reversing function of your Novak ESC may not work properly. This 30 degrees of timing is accounted for in the speed controlís commutation sequence.
so that means turning 5 deg.. of timing clockwise is to lower the timing not to increase timing.. hope this help....... good luck with your racing...
TAMIYA TRF416X
Old 10-19-2009, 10:31 PM   #27
Airflow's Avatar
Ha ha ha. Got it. Sorry bout that and thanks for clearing it up.
brushless timing cyclone speed Electric On-Road 2 06-28-2008 05:36 AM
Timing Question VenturaDC Electric On-Road 4 04-26-2008 12:46 PM
Novak GTB 6.5 Brushless Question chumanji Electric On-Road 7 02-16-2006 11:41 PM
Novak Brushless Question? ChrisE Electric Off-Road 5 04-12-2004 11:57 AM
Novak Brushless question Calvin Ng Electric On-Road 4 04-22-2003 06:40 PM
