Robitronic Dyno as a charger?
Has anyone used the robitronic dyno as a charger for GP3300's, I am confused over the delta peak. On my Pulsar it is arranged as 15mv, 20 mv, 25mv etc. On the dyno charging function it has delta peak arranged like 0.15, 0.20, 0.25 etc I have been told that 0.15 would be equal to 150mv!
Yes, 0.15 would be equal to 150mv. Iīm not sure of the lowest delta peak with the Robitronic as I never used the charging function of the dyno but I think 0,10 = 100mV should be the lowest. But what I know is the Robitronic dyno was designed some years ago when there were no NiMh-batteries available. So I think itīs designed for NiCad-batteries only. With some of the Sanyo NiMhīs you can use the 100mV setting but I think for the GPīs itīs a little bit too much. Maybe a different thing is the temperature controlled charging mode.
Despite this I think itīs by far the best dyno available.
As you have a Pulsar why do you want charging with the Robitronic? I donīt have a Pulsar but I think itīs much better for charging GPīs than the Robitronic.
As a Robitronic Dyno owner, my question is:
Why would anyone want to use a $600+ (usd) Dyno as a Charger?
I love my Robi as a Dyno, but to use it as a Charger, sacrilege!
