Old 09-05-2009, 05:57 PM   #286
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Lightbulb
Originally Posted by Tired Racer View Post
True/False...
1) Your ptx transponders come with 21 IDs. True
2) 20 of the IDs are from a huge pool of IDs owned by MRT. False, well they are from the pool, but stay the same in all the ptx's
3) A custom ID is assigned to a customer as their ptx default ID and for reordering. False
4) A custom ID still belongs to the huge pool of IDs and can show up as one of the 20 IDs in other ptxs. True/False... it can show up as the "21st" number again
5) A cloned ID remains owned by the customer and kept out of the huge pool of IDs if the customer does not trade in the AMB transponder. True
6) A cloned ID is handled as a custom ID if the customer trades in the AMB transponder.True
Thanks!
From the FAQ at MRT
PTX ID Numbers
The PTX is available as individually numbered transponders(due to the AMB system having 'coded' ID numbers we cannot produce new numbers, ID numbers are "not" guaranteed unique)the ID number of each transponder can be changed by use of a 'setup' button (20 alternative ID numbers are available). Each individually numbered transponder has its 'custom' ID number written on the supplied instruction sheet with the 20 alternative numbers also listed as two sets of 10 ID's. Repeated numbers are not available for custom ID non-clonetransponders. Only cloned transponders can have identical ID numbers supplied, following an original AMB transponder having been sent to us to have the ID number clone copied.
Cloned PTX transponders can have copied numbers from either personal transponder (PT) or rechargeable battery type (RT)'hand out' transponders used at clubs. The transponder mustbe sent to MRT in the UK together with a 'clone order form.
Ed Anderson is offline   Reply With Quote
Old 09-05-2009, 06:57 PM   #287
Is this like a self-imposed rule so there are less transponders in the same area with duplicate custom ids?
8ight 2.0 RTR and RR Part Diffs> http://www.rctech.net/forum/6212031-post1.html
Tired Racer is offline   Reply With Quote
Old 09-05-2009, 11:55 PM   #288
i received my 2 custom ptx's 10 days after ordering them. i will install them tomorrow morning for our big labor day race. thanks for the fast service!
650dave is offline   Reply With Quote
Old 09-07-2009, 08:57 PM   #289
Thumbs up
both ptx's worked perfectly this weekend! i would recommend them to anyone looking for a personal transponder.
Old 09-08-2009, 06:43 AM   #290
Originally Posted by jonest View Post
My PTX was working great until a friend of mine opened the casing thinking of cutting the wire short, but found that the silicone was wrapping the PT and put back the casing without doing anything. Right now, the PTX is causing the car glitch! (removed PTX car was OK). Any1 encounter this? Terry, any idea of the problem and what's the solution? Send it back?
Thanks.
Hi jonest, removing the base from the casing will not cause any problems. I'd guess something else has changed with the car/setup, it could be the connection to the receiver, maybe check the PTX plug and receiver socket. If there is a problem you can't work out drop me an email and I will see what we can do to help fix it.
Terry_S is offline   Reply With Quote
Old 09-08-2009, 06:47 AM   #291
Hi 650dave, that's great you like your new PTX transponders
Enquiries note: I forgot to say about sending PM's on rctech, I'm not a regular here so please send to me by email at [email protected]
If you send a PM it might be a while before I reply!
Old 09-08-2009, 11:20 AM   #292
jonest's Avatar
Opened up the case and removed those silicons and seems like the neg wire touching the pos side. I'd shortened the wire and did a range test (ard 80'). Cars seems to respond positive (no glitch) at this moment. Will head out to the track and shall report back.
Thanks Terry
P/s: Btw the new PTX casing seems awesome. Would you be offering the casing to existing PTX users? It seems the base is about the same.
jonest is offline   Reply With Quote
Old 09-08-2009, 05:20 PM   #293
Ok thanks, I will wait for you to report back. Hope it all works ok again now.
Glad you like the new PTX casing! The new PTX hard cased version is a new design, the base is the same size but the height is lower. The old PTX and new PTX cases are not compatible, we don't have any upgrades available.
Old 09-09-2009, 01:01 AM   #294
Rogier's Avatar
Terry, can you estimate the turnaround time for cloning an AMB from Holland? Thanx!
My RCTech trader feedback: http://www.rctech.net/forum/trader-feedback/146331-rogiers-feedback-thread.html
Rogier is offline   Reply With Quote
Old 09-09-2009, 02:12 AM   #295
Hi Rogier. The turnaround time for cloning is about a week with us plus the shipping time back to you. Details are on the clone order form at www.rclaps.com also the PTX FAQ page has transponder and cloning information. If you need your AMB returned early before your clone(s) there is an option with the extra shipping charge, details are on the form.
Old 09-09-2009, 02:23 AM   #296
entitymugenmtx's Avatar
Trader Rating: 81 (100%+)
Send a message via AIM to entitymugenmtx
where can we buy a ptx in the US
SPONSORS.....MY CHECKBOOK....
entitymugenmtx is offline   Reply With Quote
Old 09-09-2009, 01:56 PM   #297
V12
V12's Avatar
You have to buy the PTX from MRT in the UK http://www.rclaps.com/ but that isnīt a problem.
V12 is offline   Reply With Quote
Old 09-14-2009, 04:27 AM   #298
We have the PTX available from stock. The new PTX case version replaces the old one, there is currently an introductory discount price offer. Orders for 10+ quantity have an extra 5% discount available.
Old 09-14-2009, 04:57 AM   #299
Low_E's Avatar
Send a message via MSN to Low_E
well, i just tried to order a new clone PT but the webshop seemed offline due to an update
The MRT WebShop is closed for upgrade
apologies for any inconvenience.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 09-15-2009, 02:09 AM   #300
Hi Low_E,
PTX transponder ordering is at www.rclaps.com by clicking on the green 'More Info & Ordering' link,
the other MRT WebShop pages are offline due to a store upgrade.
Note: to see US$/AUD$/Euro prices click 'Buy' on product pages
to enter the checkout and select country using dropdown then
checkout page will show updated prices.
Email [email protected] for help with ordering.
AMB-RC Transponder andrew-01 R/C Items: Wanted to Buy 9 06-29-2009 04:41 PM
aMB transponder from AMB willabong Australia Wanted to Buy 0 09-16-2007 07:19 PM
Blue aluminum transponder mount and transponder fat500 R/C Items: For Sale/Trade 2 08-12-2006 07:13 PM
AMB Transponder slippery49 R/C Items: Wanted to Buy 3 05-24-2005 07:44 PM
AMB Transponder FS F1Junkie R/C Items: For Sale/Trade 3 05-09-2005 09:45 PM
