Old 06-09-2008, 08:49 AM   #1
peterchia41's Avatar
Default Punching Hole
Dear All,
Sorry to trouble you all but I would like to ask... How do you punch hole on a body shell? (I know, its a noob question)....
Reason I ask is 'cos I have such a hard time doing this.
peterchia41 is offline   Reply With Quote
Old 06-09-2008, 09:02 AM   #2
Trader Rating: 23 (100%+)
if you heard of em its just a piece of metal thats sharp and shaped like a cone and you just make the hole with it.http://www.rcplanet.com/v/vspfiles/photos/ASC1593-2.jpg
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-09-2008, 09:05 AM   #3
tc3team's Avatar
Originally Posted by peterchia41 View Post
Dear All,
Ideally, you need something like this:
http://www.rc-direct.co.uk/3racing-r...ies-p-145.html
Although, if you are very careful, you can use a hobby knife to make a hole, then an old big X head screwdriver to ream/stretch the plastic big enough for a body post or transponder mount hole
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 06-09-2008, 09:26 AM   #4
Hi,
I have a reamer but is there a way to use it better? I take like 'hours' just to make the hole with it and always not sure if it is punched correctly!
Haiz
Old 06-09-2008, 09:37 AM   #5
tc3team's Avatar
Hi,
Haiz
Well, the measuring to get the hole in the right place takes the time, measuring between the centre point of both front and rear wheel arches, then the dimensions between the outer edge of the shell and where the body post is takes some accuracy Different sized shells dont help either
Ive never found an easy way to get it all right, just take your time. Anyone else out there got a better way?
as for actually using the reamer, hold it UBER straight on the point you need it and use a small block of wood or something underneath to put the pressure onto, making sure both the shell and wood are flat. The angles are a killer sometimes and make the reamer slip....
Old 06-09-2008, 09:39 AM   #6
Trader Rating: 16 (94%+)
Dear All,
Do you mean the body post holes?
If so, I mark them with a marker and cut them out when the body is still clear. Before you paint the body, just put some tape over the hole you made, on the outside of the body of course.
kn7671 is offline   Reply With Quote
Old 06-09-2008, 09:55 AM   #7
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
if your body is already painted just take some small dabs of peanut butter and put on top of your body posts. then set the body down carefully the way it should sit and push lightly onto the body posts. pull body straight off and take a small drill bit and drill in the center of your peanut butter mark. use your reamer to open the holes up gradually to the right size. Slightly bigger then the post. Poof your done. shoudl take you about 15 min to do 4 body post holes....o yeah and rememebr to clean the left over peanut butter off the posts
If your body is clear do as already said. set body on chassis and mark holes with sharpie then drill them, then ream them.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Brush Hole Jig Slapmaster6000 Electric On-Road 2 10-10-2006 07:31 AM
Light Oil & Small Piston Hole vs. Heavy Oil & Large Piston Hole Rich Panganiban Nitro On-Road 2 01-26-2006 04:24 AM
to cut a hole or to not cut a hole? kh15 Electric On-Road 6 10-07-2004 11:17 AM
[email protected] is an @$$hole... Super Steve Buyer/Seller dispute and Feedback discussion forum 6 01-17-2004 06:33 PM
