Old 06-07-2008, 12:42 PM   #1
Default TC3 Pinion Gear Mesh Adjustment How ??
Hey guys, just got my TC3 I think the mesh is off because it slips sometimes and sounds horrid. Can someone tell me how to adjust the gap? Thanks
SDNitroGuy is offline   Reply With Quote
Old 06-07-2008, 01:33 PM   #2
RCSteve93's Avatar
There should be 2 screws on the heat sink. Loosen them and move the motor closer to the spur.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 06-07-2008, 01:36 PM   #3
Mike Haynes's Avatar
Don't forget to re-tighten the screws.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 06-07-2008, 02:05 PM   #4
NOZ69's Avatar
You should be able to slightly rock the spur, try this in several spots with out moving the pinion.
Another way is to put a cigarette paper between the spur and pinion and just move the pinion up to the spur and tighten motor mounts, then just rotate the paper out and it should be the perfect mesh.
I just do my first suggestion & never have any probs with mesh issues.
Good luck
Cheers
FT TC4, LRP TC Sphere, LRP X-11 13.5
SC10 4x4
M03M Suzuki Swift
Power by Feral
Sanwa MX-3 FHSS
NOZ69 is offline   Reply With Quote
Old 06-07-2008, 02:06 PM   #5
I figured out how to adjust it, I put a piece of paper between the two and pushed it together then tightened it down to AE specs (gap, etc.) but it still isn't catching well, the pinion spins freely sometimes. Do I need a new spur gear?
Is a piece of paper good for the gap?
Old 06-07-2008, 02:06 PM   #6
Maybell's Avatar
This question requires a little more info to answer...
-press the gears together
-pull the mesh barely loose and tighten the screw on the inside of the motor mount(heat sink)
-the screw on the outside that has a spring on it : tighten it only enough to put some pressure on the spring(do not overtighten)
-check the mesh by rocking the spur back and fourth, feeling the gap
-again make sure you only have a tiny amount of space between the gears
good luck!
Sean
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 06-07-2008, 08:13 PM   #7
Ended up being a stripped spur gear that kept me from getting the mesh just right. Gotta pickup a new spur gear
About Gear Mesh bo_barger Nitro On-Road 2 03-29-2008 08:55 PM
Spur/Pinion mesh on B4 Born2Lose Electric Off-Road 1 04-12-2007 03:37 PM
gear mesh RebelRacer Rookie Zone 6 08-03-2004 07:45 PM
Gear Mesh JayBee Electric On-Road 12 05-15-2004 04:47 PM
Gear Mesh on TC3.... RoadRat Electric On-Road 3 05-29-2003 12:36 PM
