Old 06-06-2008, 12:54 AM   #1
tjompa's Avatar
Default improve traction on a corally F1?
Hello outthere!
I was trying to race my new corally F1 on our tarmac track yesterday, was adjusting the t-bar and the dampers but couldnt find enough rear traction on the car, i need some help with this problem, how should i setup the car and maybe go with another wing? tires? i dont care how the car looks like, just itīs fast and controllable.
happy for answers.
//Tomas
tjompa is offline   Reply With Quote
Old 06-06-2008, 01:23 AM   #2
Was the track prepped? What tires were you using? What's your setup?
Old 06-06-2008, 07:30 AM   #3
tjompa's Avatar
silverstar original tires, did use traction formula one hour on the rears.
The track is slippery this time of year but i just wanna have some more rear
traction anyways. original damper setup and the friction side dampers had hard syrup in them, original wing. Should this car perform better with a group c body?
Old 06-06-2008, 10:51 AM   #4
edseb's Avatar
Pan cars like the Formula 1 car you have are really dependant on tires. The other stuff is fine tuning. Sounds like the track you run on might need more prep too, but if that's not an option, take a look at softer compounds.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 06-07-2008, 09:20 PM   #5
SSUPERSTARR's Avatar
Originally Posted by tjompa View Post
Hello outthere!
happy for answers.
//Tomas
If you're still using the kit T-bar 2mm (stock), you definately need to go to the optional 1.6mm T-bar.
Another recommendation, a foam tire conditioner like SXT 2.0 or Trinity tire tweak needs to be applied first. Allow it to absorb into rear tires only. After that, apply Paragon FX-II or Trinity red dot tire additives/traction compound. Allow to absorb, wipe dry before heading to the track. This would be for all around rear traction (grip).
SSUPERSTARR is offline   Reply With Quote
Old 06-07-2008, 09:43 PM   #6
tallyrc's Avatar
most important part of track prep is just blowing it off.. did you really mean that you sauced the tires for an hour?
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 06-08-2008, 04:44 AM   #7
Change your tires! We us GRP tires on our F1's and Pro10's. Pink rear, Purple front. Perfect traction, and they last a long time.
Check their website for compounds: grpgandini.com/uk/index.html
Johannes is offline   Reply With Quote
Gearing for Traction/Slipper for Traction RCRat Electric Off-Road 2 08-27-2008 03:55 AM
High-traction & low-traction? bloodlust Malaysian R/C Racers 4 12-06-2007 09:17 AM
Improve this..... Mabuchi540 Electric On-Road 2 01-23-2005 09:50 PM
ESC improve performance?? blixelX Electric On-Road 11 08-17-2003 10:09 PM
Racing. How to improve it? fastolfart Australian Racing 105 11-12-2002 06:41 AM
