charging orion lipo...... >
Old 06-04-2008, 06:05 PM
  #16
RC MARKET's Avatar
Originally Posted by or8ital View Post
Higher C charge rate just charges faster and possibly reduces overall life of pack. It should have no performance impact.
higher C Charge , will lose life & not have more power ?
RC MARKET is offline
Old 06-04-2008, 06:07 PM
  #17
Trader Rating: 38 (100%+)
Yes.
or8ital is offline
Old 06-04-2008, 06:16 PM
  #18
RC MARKET's Avatar
Yes.
ok thanks !
but do you need discharge Li-Po battery ?
Old 06-04-2008, 06:21 PM
  #19
No need to discharge. SMC said to cycle to get heat up (better performance when cells are hot) but you can just heat them instead.
or8ital is offline
Old 06-04-2008, 07:27 PM
  #20
lem2's Avatar
Default How many??
I use a MuchMore Silent Charger, how many amps will I charge a 4800 Orion Lipo and an Orion 3600?
Do i need the trakpower v-balance to charge thru?
Lem
lem2 is offline
Old 06-04-2008, 07:35 PM
  #21
espresso1967's Avatar
Trader Rating: 18 (100%+)
Originally Posted by POUNDITRACING View Post
You can get away with charging at 2C. but you must allow time for cooling after your race. I ran the same 3600 for about 3 clubrace days and the pack started to swell. I was only charging at 1C. You have to be careful. I would invest in another pack or two. I don't see your packs lasting long if you continue on this path.
What is the recommended cooling off period for a lipo after a race? I picked up three lipos but was thinking while practicing, charging the first one that I just finished practicing with, but did not think about letting it cool off. I would hate to have a lipo failure at the track.
espresso1967 is offline
Old 06-04-2008, 07:45 PM
  #22
Lem
4.8 amps for the 4800. 3.6 amps for the 3600.
or8ital is offline
Old 06-04-2008, 08:26 PM
  #23
lem2's Avatar
thanks!
lem2 is offline
Old 06-05-2008, 07:49 AM
  #24
POUNDITRACING's Avatar
About 20 min. 10 on a fan.
POUNDITRACING is offline
Old 06-05-2008, 11:43 AM
  #25
RC MARKET's Avatar
But SMC said Li-Po battery had remember.
tomorrow can test new 30C Li-Po la !!
