Old 06-01-2008, 03:41 PM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default Did I blow up my esc?
I have a orion 3600 lipo and mamba max esc
when I went to plug the lipo into the esc the connectors made a few sparks and got instantly hot - so hot that all the solders came undone. The battery was kinda warm afterwards - but the cells didnt puff.
Im guessing this is some kind of a "short". The esc was on when I plugged the lipo - do you guys think I damaged my lipo or esc
havnt tried to run the lipo or esc again yet
wstuart is offline   Reply With Quote
Old 06-01-2008, 03:54 PM   #2
Trader Rating: 16 (94%+)
Sounds like you might have plugged your LiPo in backwards, reversed the polarity. This would cause the issue you described. Also, a wire to your ESC, motor or battery, may have been touching another wire or was grounded. If the ESC was previously working, than I doubt it suddenly blew for no reason.
kn7671 is offline   Reply With Quote
Old 06-01-2008, 04:14 PM   #3
Trader Rating: 23 (100%+)
happened to me with a nimh battery aswell and my battery was just bad. the whole esc went up in smoke and it was very hot like yours was. either the battery was plugged wrong or the battery is bad most likely
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-01-2008, 05:31 PM   #4
chris moore's Avatar
Trader Rating: 88 (99%+)
Did the magic smoke come out? This may sound wierd but smell the esc, if it has a burnt smell then you've fried a fet or two and even if the esc did'nt smoke it will most likely fail very soon.
chris moore is offline   Reply With Quote
Old 06-01-2008, 05:44 PM   #5
wstuart's Avatar
The esc didnt smoke or have a burnt smell, but teh battery had a burnt smell - where the chip and plugs are. -
do ou guys think the battery would be safe to use - cells didnt puff - and it takes a charge just fine
Old 06-01-2008, 05:45 PM   #6
wstuart's Avatar
i think i just got the polarity wrong
Old 06-02-2008, 03:22 AM   #7
t4m1y4niac's Avatar
reverse polarity = blow up
SABRE S4 by TOP RACING....
t4m1y4niac is offline   Reply With Quote
Old 06-02-2008, 03:46 AM   #8
Drifting101's Avatar
always remember guys electronics work on smoke and if smokey esacpey electronics no worky no more
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 06-02-2008, 11:26 AM   #9
joe of loath's Avatar
depends where the short was. if it was in the plug your ESC is safe. if it happened in the ESC or the polarity was switched it's run out of smoke...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 06-02-2008, 11:43 AM   #10
Trader Rating: 38 (100%+)
what about bad smell but no smoke?
or8ital is offline   Reply With Quote
Old 06-02-2008, 11:45 AM   #11
scootr117's Avatar
New THS rule......No Taco dip in the pits...=....no smell
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 06-02-2008, 12:13 PM   #12
Bigshades's Avatar
Trader Rating: 22 (96%+)
+1 !!!
wstuart, try plugging in a different battery, with certain (correct) polarity, into you MM. Perhaps it was a fluke. Some electronics are built in with protection diodes, to protect them from reverse polarity. However, that may not account for the heat.
Cheers!
Bigshades is offline   Reply With Quote
Old 06-02-2008, 01:30 PM   #13
My question was serious. Bad smell but no smoke. Am I OK?
Old 06-02-2008, 02:56 PM   #14
Ferrarimk13's Avatar
Send a message via AIM to Ferrarimk13
doubt it, you might have melted something inside, like the plastic part, but you can try it out. if it does work, your esc might go bad sooner than you think.
Press Alt+F4 for a good time.
Ferrarimk13 is offline   Reply With Quote
Old 06-02-2008, 08:32 PM   #15
Rommel's Avatar
I did this once when i first got my 3600's as the polarity are switched compared to the 4800's
Reading this reminds me of advice I give customers, at the car audio shop I work at, when they call with problem with amps or subs. I say, "did you let the smoke out?"
Rommel is offline   Reply With Quote
Blow Out Tony Vega R/C Items: For Sale/Trade 18 08-02-2007 10:19 PM
ST-r Blow-out chowderhead72 R/C Items: For Sale/Trade 14 06-14-2007 08:35 PM
Did I Blow my GTX cpatel529 Electric On-Road 9 04-01-2007 08:38 AM
Did I Blow my GTX? cpatel529 Electric Off-Road 5 03-23-2007 04:31 PM
Did I Blow It? rustyrever Monster Trucks 12 05-18-2006 07:31 PM
