Old 08-06-2003, 08:27 PM   #31
davioh's Avatar
Originally posted by rtypec
I Just noticed this:
The holes for the wheel axles appears to be too large for just the axle to hang from. This may affect accurate measurements of camber.
Other than that, this looks like a setup system that Mr. Hudy would be proud of.
wait so the holes on the side is to measure the chamber? my dad couldn't figure out what the dials were
davioh is offline   Reply With Quote
Old 08-06-2003, 08:35 PM   #32
pkranger63's Avatar
The holes on the side should be just large enough for the axels of the car to fit through. The triangle pieces should be able to move from side to side, this is what measures the camber.
Matt
pkranger63 is offline   Reply With Quote
Old 08-06-2003, 08:57 PM   #33
NMRCDude's Avatar
Send a message via AIM to NMRCDude
Yes, your dad did it correctly. Camber is measured off the Y-axis i.e. Vertically with a few degrees left or right (positive or negative)
NMRCDude is offline   Reply With Quote
Old 08-07-2003, 11:59 AM   #34
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
did anyone find the perfect measurments???
Calvin Ng is offline   Reply With Quote
Old 08-07-2003, 12:19 PM   #35
Originally posted by pkranger63
I would make one just for fun. I have a Sherline mill and lathe that I play around with, most of the parts I make I could buy cheaper but I am a tinkerer. Like I said my only problem is finding a acurate way of etching the degree marks. I am looking into it though.
Matt
Not a problem, Matt. Use a "Single Point" tool. Looks like a piece of drill rod, sharpened to a point. One half of the point is ground away to produce a cutting edge. Thats a excellent tool for making the lines you mentioned! Go to a machinist tool supply place and tell them what you want to do and they'll hook you up to what you need. If you've got a mill, you in the house, dog!
Graphitedust is offline   Reply With Quote
Old 08-07-2003, 12:28 PM   #36
davioh's Avatar
Originally posted by Pit Crew
Question:
how do you get a camber reading? It seems that the peice that would tell you what the camber is is always at 0degrees (because its straight up and down)
take off the bottom screw and then the triangle moves
Old 08-07-2003, 04:33 PM   #37
pkranger63's Avatar
Thanks for the tip graphitedust! I will pick one up. Since I already have a Hudy set-up system, getting the dimensions will be easy. I found a place that sells plexiglass. Time to fire up the little Sherline and let the plastic chips fly
Thanks again
Matt
Old 08-23-2003, 08:03 PM   #38
Registered User
Calvin Ng's Avatar
hey just wondering davioh but what does your dad do for a job
home made funny car kenazzo2000 Malta R/C Racers 4 07-31-2009 10:46 AM
Home made tyre truer? Helix70 Nitro On-Road 4 03-23-2006 08:08 PM
HOME MADE DYNO DOES THIS WORK? PRO 2 RACER Australian Racing 4 12-29-2005 03:26 PM
Home made Dyno does this work PRO 2 RACER Electric On-Road 8 12-29-2005 01:58 AM
Home Made Batteries?! Nitrus~Power Electric On-Road 18 02-11-2003 02:51 PM
