Old 08-05-2003, 11:01 PM   #1
Pandora's Box's Avatar
Default Final Drive Ratio
What final drive ratios do you suggest from your experience for 8, 9, 12, and 23 turn motors for touring cars on asphalt? and maybe your reason based on the track layout, motor wind, temperature, etc......anything else?
Have a great day!
Pandora's Box is offline   Reply With Quote
Old 08-06-2003, 12:45 AM   #2
Neil Rabara's Avatar
That's a lot to answer, would you be more specific for your own racing conditions?
Neil Rabara is offline   Reply With Quote
Old 08-06-2003, 01:44 AM   #3
Ok. Let's make it specific.
I just wanna know in what region you would gear the car for the specified turn? Let's say an 8, 12, and 23 turn
Track: asphalt. small but flowing.
Ambient temp: 32deg Celcius
Cheers!
Old 08-06-2003, 04:46 AM   #4
Regional Moderator
Addict sa RC's Avatar
What I do is adopt the + 10 rule for mod (20 tooth for a 10 turn, 21 for a 11 turn,...) and adjust from there. This is with a XXXS and 90 spur.
For stock, small but flowing track, I'd say start with 6.2 then adjust from there.
This is just me though.
Addict sa RC is offline   Reply With Quote
Old 08-06-2003, 05:41 AM   #5
kt racing's Avatar
Send a message via AIM to kt racing
With a tc3 8 turn 20 pinion 72 spur
12 turn 24 pinion 72 spur
19 turn 26 pinion 72 spur
27 turn 28 pinion 72 spur
kt racing is offline   Reply With Quote
Old 08-07-2003, 01:07 PM   #6
JohnnyRotten's Avatar
I use 9t 25/90 , 12t 30/80 on my HPI pro 3
JohnnyRotten is offline   Reply With Quote
Old 08-07-2003, 02:13 PM   #7
It depends on the size of the track you're racing on, and the car you're using, every car drive train is different.
milf is offline   Reply With Quote
Final drive ratio Starteur Electric On-Road 2 02-04-2008 07:33 PM
Final Drive Ratio on TRF 414 Arun Electric On-Road 8 03-03-2004 04:28 PM
Final Drive Ratio ??? FlyinGT Australian Racing 3 02-29-2004 12:06 AM
Hpi Mt Final Drive Ratio??? True R/C Racing Electric Off-Road 0 02-28-2004 11:10 PM
how do i find out my final drive ratio?? FlyinGT Electric On-Road 3 02-28-2004 09:40 PM
