Old 05-24-2008, 05:48 AM   #1
Default Brushless and LiPo
I got out of electric racing just before the brushless and lipo craze set in. I want to get back into electric racing again but do not know who makes good brushless motors or lipo batteries and chargers. Any suggestions?
Also, what do i have to do differently to set up the brushless and lipo components?
lemansracer is offline   Reply With Quote
Old 05-24-2008, 09:14 PM   #2
Trader Rating: 16 (94%+)
LiPos:
Orion, Core-RC, SMC, and Track Power have proven performance on the track. New the scene are the Reedy LiPo's.
Brushless Motors:
Novak, Speed Passion, LRP, Trinity, Orion, Hacker, Losi, etc..... All have pro's and con's.
As for setting up the components, its just like a brushed motor and NiMH battery. The only thing you need to do for LiPo is add a little weight to the battery since they are so much lighter than NiMH packs. Gearing a brushless motor is much different than Brushed. Follow the manufacturers recommendations for a starting point if racers at your local track don't have tips for you.
kn7671 is offline   Reply With Quote
Old 05-27-2008, 05:36 PM   #3
Default Chargers?
Will a regular nimh/nicad charger work or does it need a conversion? Or are there special chargers for lipos?
Do i have to discharge the lipos like the nimh/nicads or can i just top them off?
Are lipos legal for competition yet?
Old 05-27-2008, 05:40 PM   #4
Trader Rating: 38 (100%+)
Lipo is approved by ROAR but local tracks may differ so talk to them about what they allow. Not all lipos are allowed. ROAR approves certain packs.
Yes a charger that does lipos (CC-CV charge) is needed.
or8ital is offline   Reply With Quote
Old 05-27-2008, 05:40 PM   #5
Mason's Avatar
how about that search function..
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-27-2008, 09:00 PM   #6
act2007's Avatar
Trader Rating: 46 (100%+)
I've been using the Novak Brushless/GTB combo and the Team Orion
Advantage charger/Platinum 4800 Lipo for the last three years, and
all I can say is, very reliable and lots of power!
Ask around in your LHS, I'm sure they'll guide you to the right direction.
Go Lipo/Brushless, no more discharging and no more cleaning. Just more playing time on the track!
act2007 is offline   Reply With Quote
Old 05-27-2008, 10:16 PM   #7
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
my picks and recommendations:
Brushless ESC (Sensored)
LRP TC Spec
Brushless Motors (Sensored)
LRP
Orion
LiPo packs (hardcase)
Orion
Peak
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-27-2008, 10:39 PM   #8
factory racer's Avatar
whats the difference between sensored and non sensored brushless systems?
factory racer is offline   Reply With Quote
Old 05-29-2008, 04:46 PM   #9
Default Competition
What winds (motor winds) are allowed for each of the classes of touring car?
Old 05-30-2008, 10:38 AM   #10
Brian Searles's Avatar
Send a message via Yahoo to Brian Searles
A sensored system uses a hal sensor with a sensor wire going from the motor back to the esc to tell the esc where the rotor position is and when to commutate. The advantage to sensored is starting, especially in higher turn motors.
A sensorless system does not have a dedicated sensore wire going from the esc to the motor, but instead it uses the motors windings to let the esc know where everything is. The advantage is that you are not stuck with a "mechanical" type of setup telling the esc when to fire, but in a sensorless setup you can react and adjust as needed, so really it is a more efficient setup when you get moving.
Worth noting that with the new RS from Tekin you get the best of both worlds. A sensored start, then it switches to sensorless and uses the windings in the motor once you get moving.
Hope that helped a little.
RC12R5-Tekin RS 17.5 system, Parma Speed Body/Tires, Trinity EP4600 cells.
Brian Searles is offline   Reply With Quote
Old 05-30-2008, 10:40 AM   #11
Send a message via AIM to Dawn Sanchez
Dawn Sanchez is offline   Reply With Quote
Old 05-30-2008, 11:35 AM   #12
Default Gearing
Is the gearing different for brushless versus brushed?
Old 05-30-2008, 11:43 AM   #13
Yes but gearing within motor types is different too based on brand and turns. As was mentioned above. Lots of these threads you created have been covered quite a bit before in the past. Might want to use search to see what you can find out there. There is a wealth of info over the last 2 years for brushless and lipo.
looking for a brushless and lipo TeamFast R/C Items: Wanted to Buy 6 07-03-2008 05:03 AM
Brushless or LIPO DomainG8 Electric Off-Road 19 05-14-2008 12:49 PM
10.5 Brushless & Lipo Steve B Electric On-Road 9 10-30-2007 09:45 AM
Best brushless and LiPo for 4wd? Terry M Electric Off-Road 12 06-21-2007 08:49 AM
Looking for 1/10 brushless and lipo gndprx R/C Items: Wanted to Buy 3 12-21-2006 04:28 PM
