RMS-1 - Rotor Measurement System >
Old 02-11-2013, 04:40 PM
  #31
Originally Posted by MR-RMS View Post
21 seems to high for 13.5 they should read 12.9 to 14ish. where you measureing Hot?
Where can i get one of these MMS meters?
Jason Snyder is offline
Old 02-11-2013, 06:28 PM
  #32
You can find the at Lefthander-rc.com, Ovalstuff.com or from me ([email protected]) directly.
Thanks for your Interest
MR-RMS is offline
Old 09-12-2013, 07:50 AM
  #33
Default Dumper is Ready!
It's been a long road but the Dumper is ready!
In this small compact design you’ll be able to:
1) Discharge up to 45 Amps (1S) 35 Amps 2(S)
2) Select a voltage cut off to stop the discharge cycle
3) Monitor the voltage and discharge Amps in real time.
4) Monitor elapsed time of the discharge
5) Monitor the milliamp hours from the battery
6) See the time the battery crossed 4 Volts ( 1 Cell) 8 Volts (2 Cell)
7) View the discharge voltage at 30 second “snap shots”
They are available on the website. There are two types available, one is covered in a carbon fiber wrap. The Other I had anodized blue.
Thanks again for your support
Jonathan
Attached Thumbnails RMS-1 - Rotor Measurement System-image.jpg   RMS-1 - Rotor Measurement System-image-1.jpg
File Type: pdf
File Type: pdf
MR-RMS is offline
Old 09-12-2013, 08:05 AM
  #34
Team EAM
Trader Rating: 79 (100%+)
Ive been using one of the prototypes now for about 9 months and its has never let me down. Its a great way to save on space to discharge lipo's and be able to grade them to see how they are under a high amp discharge. Anyone that is at IIC that wants to see how it works I will have mine there on display.
EA
EAMotorsports is offline
Old 09-12-2013, 06:39 PM
  #35
Wow sold out already I can't thank you enough! You guys humble me.
I'm already working making the next batch. Too bad the day job is getting in the way LOL
Thanks again Jonathan
MR-RMS is offline
Old 09-12-2013, 07:28 PM
  #36
Mr RCTech's Avatar
Does the dumper give a IR number as it dumping?
Mr RCTech is offline
Old 09-12-2013, 07:45 PM
  #37
No IR I did the how long did the battery hold 4 or 8 Volts instead.
MR-RMS is offline
Old 09-12-2013, 10:02 PM
  #38
Trader Rating: 20 (100%+)
Originally Posted by trailranger View Post
I even had one show 1296, and I'll save that one for a big race!
what class do you run and what size of rotor. That gauss reading would be weak in a TC or off-road vehicle
goots is offline
Old 12-05-2013, 09:14 AM
  #39
I've been working hard to catch up on the Dumper pre-orders I'm almost there.
Look for them soon on the web site.
Thanks again for your Support
MR-RMS is offline
