Old 08-03-2003, 06:03 PM   #1
CGR
CGR's Avatar
Default Losi shocks on AE car
Building AE shock is a pain and I was wondering if anyone has tried useing XXXS or other appropriate length Losi shocks on a TC3? Do both brands of springs work on the losi shocks?
CGR is offline   Reply With Quote
Old 08-03-2003, 07:32 PM   #2
Super Moderator
Grizzbob's Avatar
Why do you think the TC3's shocks are a pain? Is it the filling & bleeding of them?. If so there is something you can add that'll make it a LOT easier, just replace the shock caps with ones from Yokomo shocks(can't remember the part # right now though). They have a bleed hole & screw, so all you do is fill the shock completely(almost overflowing), then put some oil in the cap(with the screw installed), quickly screw on the cap & then take out the screw, slowly push the shock shaft all the way in & then reinstall the screw. Then your shock should be just right(it may be a tick messy, but IMO no more so than doing it without a bleed screw)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-03-2003, 08:34 PM   #3
CGR
CGR's Avatar
I tried the yok shock caps and they leaked. I have found it is far easier to setup and build losi shocks.
Old 08-05-2003, 11:03 AM   #4
CGR
CGR's Avatar
well it looks like I may have to be the guinea pig
Old 08-05-2003, 11:22 AM   #5
RCBuddha's Avatar
Trader Rating: 35 (100%+)
CGR,
Its kinda funny that you brought up this topic. I happened to wonder the same thing as you, but I went ahead and tried it. The shocks will fit, but the major problem I had was the fact that there was not enough thread on the shock bodies to help set proper droop/tweak. I'm sure with some more work, I could get it to fit perfectly, but I it was more an exercise to see if it would fit than anything else. If you decide to try it, let me know your results.
buddha
RCBuddha is offline   Reply With Quote
Old 08-05-2003, 12:57 PM   #6
RAP66's Avatar
u want Yok style shocks??..... get a small drilll & self tap screw (like yokomo). Drill a hole in the shock cap, clean up any burrs & now u have a bleed screw like the yokomo caps...
All of my associated cars have this & it works Great
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 08-05-2003, 02:19 PM   #7
CGR
CGR's Avatar
Budda, did you use the .36 or .28 losi shocks?
Old 08-05-2003, 02:22 PM   #8
Suspended
did you use it
chillout123 is offline   Reply With Quote
Old 08-28-2003, 01:31 PM   #9
RCBuddha's Avatar
I tried both, with no success....the closest i got was the longer of the two....
buddha
Old 08-28-2003, 11:10 PM   #10
speaking of shocks..I bought a set of Hot Bodies shocks for My Sport 2 and I cant find springs to fit it anywhere..and the HotBodies website is under const...any ideas?..the lower retainer and the adjustable clamp are larger and std HPI springs dont fit quite right.
MarlboroRally is offline   Reply With Quote
WTB IRC Shocks Or Losi After Shocks Or LS2 Shocks !jAsOfRaW! Australia Wanted to Buy 0 01-25-2008 02:12 AM
Losi Micro-T / Losi LST Shocks / Stock Motors puddle Australia For Sale/Trade 8 06-04-2007 05:26 AM
Losi shocks tim fry Electric Off-Road 3 08-27-2006 08:27 PM
Looking for Losi XXX-4 Shocks Funkymojo R/C Items: Wanted to Buy 3 12-26-2005 02:26 AM
losi xxx-4 parts,and losi buggy shocks a/efreak R/C Items: For Sale/Trade 5 09-08-2005 02:32 PM
