CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks
#1156
I was thinking about the problem you are having with steering. Sounds like it could be caster issue. How do you have your front end setup? ie which caster blocks, where are the washers. etc.
Shawn.
#1158
Its not pretty, but the servo is now mounted bottom hole on the servo to the top hole on the servo mount. If I had to draw a line through the steering system, its almost a straight line from end to end. No more tie rod bind on the a arm and the ends are mounted on the back side of the servo saver. It looks odd, but I'll test it on the carpet this week.
#1159
nice pics, thanks
interesting to mount the battery all the way back
#1160
Have noticed a couple of posts about mounting up an additional 5th body post. I have not personally done this myself but was wondering if it would make any difference at stock speeds (13.5 1c lipo) running on a short carpet tracks (65ft straight).
How do you mount the 5th body post to the CRC chassis. Can anyone share some pictures that has done this before?
#1163
I just got my thunder power lipo today . There is a .25 inch gap between the lipo & top plate . Are you guys cutting the stand offs or just using foam to take up the gap ?.
#1165
That does'nt really answer my ? My ? is there is a .25 inch GAP between the top plate & the top of the lipo . Are you guys cutting the 4 stand off's or using foam to take up the space between the lipo & top plate ?.
#1167
#1168
CRC doesn't have on specifically, but a 4-40 threaded, 3/8" tall aluminum standoff should work. I've found them on the internet, but haven't stopped by Fastenall or Ace Hardware to see what they have in stock.
http://www.parallax.com/Store/Compon...Search=PWM+PAL
#1169
#1170
Where are your washers on the front end? I run 2 back and 1 front.
Shawn.
