CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks >
Like Tree1Likes
Old 08-04-2009, 09:26 PM
  #1006
tallyrc's Avatar
hippie in addition to the usual front end parts, get the aftermarket plastic bumper and a new inproved thick top pod plate...
tallyrc is offline
Old 08-04-2009, 09:27 PM
  #1007
Trader Rating: 16 (100%+)
Originally Posted by adamge View Post
In the process of building my first pan car, a GenX10. I got the first frontend slotted capture insert in, but I can't get the second one to start threading. I put it in at an angle, feel it tighten up, but this one pops out instead of threading in. The first one tightened up and then threaded in. Taking a break to let my fingers recover. Could use some moral support ;>
Obviously, you know about the downward angle; so, that's not it.
I remember having similar issues with one side of my Gen-X 10 upon initial assembly.
I took everything apart so I only had the two parts to deal with. Got it fully threaded with a 1/4" blade screwdriver; and then disassembled it to put everything together.
Bought a complete spare front end and never had a problem assemblying it.
I can visualize a specially design screwdriver that would do it...no problem. Maybe CRC is listening...again...LOL.
Bill
Still Bill is offline
Old 08-04-2009, 09:31 PM
  #1008
Get the original aftermarket kydek bumper from Manutech. Do not get their new improved (and too heavy) version.
If you have two of the top pod plates, you can superglue them together to have the same effect as the new thicker one. Use longer screws to fasten to pod.
Bill
Old 08-04-2009, 10:04 PM
  #1009
Originally Posted by hippie View Post
I just bought a used genx 10 . My track runs them with a 13.5 & single cell lipo . Are you guys just modding the stock lipo tray or is there a special tray for single cell lipo ?. I would also like to know what are the common spare parts i should have on hand ?.
I personally dont run the 1s lipo, but I thought all the 1S lipos had the "bumps" on the bottom of the battery? If it does then I would use the battery tray designed for the Sub-C cells. That would allow you to move the weight back and forth. You could also look into the bracket that takes up 2 sub-C cells so you can run your speed control at the rear of the car instead of on one of the sides.
Shawn.
Shawn68z is offline
Old 08-04-2009, 10:10 PM
  #1010
I find it easier to first go counter clockwise until the thread "clicks", then turning clockwise. Sounds simple, but since I have done this I havnt cross threaded a single plastic part.
Shawn.
Shawn68z is offline
Old 08-04-2009, 10:48 PM
  #1011
hi all im new to the forum but not to rc or racing i found a thread on here some time ago and canot find it but they were talking about 2s lipo and 1/12 pans and the hi cost i have figured out that for less than $500 someone could get started in 1/12 pans with brushless and lipo with this list PFM160921 BODY-1/12th SPEED 12, light weight
$12.95 $12.95
GRPGDY30S 1/12th mounted foam FRONT tires, Magenta (2)
$12.95 $12.95
GRPGTY33S 1/12th mounted foam REAR tires, Magenta (2)
$12.95 $12.95
CCM252042 MAMBA MINI-T BRUSHLESS MOTOR SPORT PACKAGE
1 $109.95 $109.95
CFX12000 C12 1/12th On-road Car Kit
$149.99 $149.99
Part # Description Quantity B/o Price Ea. Ext. Price
AIR94761Z Servo-Mini Digital High Torque for 1/18 Micro; 66 oz./.12 s
$69.95 $69.95
HTT126751 AGGRESSOR 3 FM 75mHz RADIO SET with 1 HS325HB servo
$55.99 $55.99
TRI22004 Balanced LiPo Battery Charger
$29.95 $29.95
ORN14007 2400mAh LiPo Experience 7.4v Battery, hard case
$32.95 $32.95
Subtotal, excluding shipping:
$487.63
it may not be xray and lrp quality but i think it could really help bring back 1/12 class please let me know what you think
2wdjunky is offline
Old 08-04-2009, 10:55 PM
  #1012
So far, no special tray from CRC or anyone else...me thinks...
For the TP5000 1S pack (no bumps), I used the solid molded battery tray and cut out a section of the slotted battery tray to firmly hold the pack in place at the front end of the tray. It is held in place with servo tape. My ESC sits behind the pack and rests on a Center Mount Speed Control Plate #1772.
The 2mm standard top deck for the rear pod and the front steering knuckles are weak spots. Get the new 4mm Top Plate #1764 and a 2-3 sets of the Steering Blocks #3251 (They come paired as left and right side components).
Bill
Old 08-05-2009, 05:19 AM
  #1013
nitrobeast's Avatar
Trader Rating: 46 (100%+)
I use the flat tray, put the lipo where i want it and tape it in. Works fine for me
nitrobeast is offline
Old 08-05-2009, 05:28 AM
  #1014
Jin
For 1 cell Lipo to fit, just cut out a square Foam block and double side tape it one on top and one on bottom if needed. simple and clean look.
Jin is offline
Old 08-05-2009, 06:25 AM
  #1015
cdee's Avatar
For the 1s SMC40/25s this tray works pretty nice. You will also be able to lower the upper deck a little if you want, or add some foam to the bottom of the upper deck. http://www.manutech.info/151104specs.html
cdee is offline
Old 08-05-2009, 02:34 PM
  #1016
Trader Rating: 20 (100%+)
Bill
For the you guys that are running 1s lipo , are you using a small reciver pack or a voltage booster like this ?.
http://www.amainhobbies.com/product_...Step-Up-Module
hippie is offline
Old 08-05-2009, 03:34 PM
  #1017
nitrobeast's Avatar
I looked on the crc site & at stormer hobbies & amain hobbies . I could not find PART # 1772 or part # 1764. I was thinking about getting the nerf wing plates i saw eairler in the thread , & mounting the esc there . Also for the you guys that are running 1s lipo , are you using a small reciver pack or a voltage booster like this ?.
I'm using the TQ Cells booster and cant complain. The lipo/reg also works fine.
Old 08-05-2009, 04:00 PM
  #1018
Is one better than the other or is there no real difference ?. I did notice the TQ booster is smaller than the novak . Also does the TQ unit increase the power to 6 volts like the novak unit ?.
hippie is offline
Old 08-05-2009, 08:24 PM
  #1019
s13evo's Avatar
Originally Posted by s13evo View Post
anyones want to buy 235mm Extension Kit for the Genx10.
$25 shipped. thanks
any new GENX10 owners want this kit let me know thanks.
s13evo is offline
Old 08-06-2009, 05:32 AM
  #1020
nitrobeast's Avatar
I picked the TQ one because of its size. Im not sure about the output voltage. I can measure it for you later today if you really wanna know.
