Old 08-02-2003, 11:54 AM   #1
Cole Trickle's Avatar
Default One-way diff versus CVD's durability
I'v been briving my HPI Pro2 approx. 3-4 month with a one-way diff. It seems to be hard on the CVD's, they are bent and twisted. I rectified them as good as I could, when it comes to the bent shape. The twisted thing, well, it wont matter much.
Our track is very tough, when one hit the barrier. The guys with shaft cars, they simply brake the CVD's, regardless of plastic, steel or what they else got. They've only been running one-way diffs for a month or so.
The best solution will be not to crash, but I dont crash much anymore. But the few crashes I do have, seems to be enough....
My Pro2 got alu MIP CVD's. If I can get steel ones, will it just be something else that brake?
Another choise is to run a one-way pulley instead, but I'll mis that nice on-power steering, especially since I'm running on a tight and narrow track !
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-02-2003, 12:01 PM   #2
utieh's Avatar
since I'm not a good driver it happenned a lot on my Yokomo,
but even with small jumps it happened I broke some aluminium ones.
I don't think you will break something else while changing for steel (u can also break them), but I have been told that 1/8 th were using Ti bones to solve the problem (already ordered for the front )
utieh is offline   Reply With Quote
Old 08-02-2003, 01:23 PM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
hey cole,
yup, one ways and spools are murder on cvd's. i was running the type t for a few months and it had steel cvd's. i broke two or three in no time. the steel bones may hold up, but the pin can sever. it's very difficult to keep durability when running solid type front ends. perhaps a solution is to run a diff up front , but tighten it down a ton, and use the center one way. the one way will unload under braking , giving you decent off power turn in, but the tight diff will pull the front around on power. it will still be slower this way, but you won't be sidelined as much.
also try to mechanically limit your steering to just more than the car will need. perhaps via some spacers glued to the carriers where the knuckles will contact. often it is hyperextending the cvd that causes the damage.
lata
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 08-02-2003, 01:40 PM   #4
dtm
dtm's Avatar
Send a message via ICQ to dtm
Front one ways are tougher on the CVD because if you crash and "launch" the car off the ground, the wheels will keep on spinning. When the car hits the ground again, the spinning wheel will come to a full stop very quickly. Normally I do not run alloy CVDs up front but use steel ones. This will help a lot, but the final solution is still not to crash....but easier said than done!
dtm is offline   Reply With Quote
Old 08-03-2003, 07:12 AM   #5
I also think big part of the problem, is that a usual diff allows the power to free out, since that if one wheel spinns, the power can slip out this way.
I also have a problem with a particular corner, if I fail in this corner, I hit the barrier frontally (T-bone!). This will also be very hard on the front CVD's.
Old 08-03-2003, 07:13 AM   #6
This sounds like an easy improvement, I'll try it !
Old 08-03-2003, 07:15 AM   #7
Sideline cost too much time !
And an advantage of using a ball diff, is that I can use the graphite outdrives, which save some rotating mass. If they just can stand the crashes ...
Old 08-03-2003, 07:17 AM   #8
Seaball, by the way, your signature is nice: an error doesn't become a mistake until you refuse to correct it.
CVD's - How do you maintain your CVD's? kn7671 Electric On-Road 13 11-27-2007 07:23 AM
MGT hardcore shock towers cvd's diff and much more $65.00 tmaxxking R/C Items: For Sale/Trade 1 05-02-2006 05:15 PM
IB vs GP - Durability forum fodder Electric On-Road 8 01-26-2006 12:55 PM
t4 cvd's, evil twin tires mounted, losi red taper mounted, kyosho tcd diff gears dylanj R/C Items: For Sale/Trade 1 11-15-2004 01:28 PM
Tungsten versus carbide diff balls Cole Trickle Electric On-Road 3 04-27-2004 03:41 AM
