Amount of droop?
Running Sport2 on carpet, with a few small bumps. Therefor I like to use droop. But how much is appropriate? 1-2 mm? Currently I got around 4-5 mm. I assume the same amount front/rear would be a good starting point?
a lower number means more droop, becase it is measured by the distance of the end of the arm from the chassis (measuring vertically). I have 7mm of droop on both ends of the car running on carpet.
Speedo
Speedo
Speedo is right. Here's some more info.TC3 manual-Look on page 26 in the manual.
I'll use more droop(lower number on gauge) for less bite conditions and I'll use less droop(higher number on gauge) for higher bite conditions.
Pardon my ignorance, I'm only two weeks into this hobby...
But, what is droop? and how do I adjust it?
I have a Corally C4.
Thanks!
-KS
Thanks!
-KS
Ignorance? Pah! "I'm better than you at racing" now thats ignorance hehe
Anyways, I don't know abou the C4 but, with the TC3 you get "droop screws" which are located on the Front and Rear arms, you adjust them by using a hex driver, or the hex thingey (what ever its called
Droop is what is known as how much your arms travel down, and with the droop screws higher up the more travel you get, and the lower the droop screws are the less travel you get. For more bumpy tracks go for more drrop, for higher traction tracks go for less droop.
Hope that helped.
Hope that helped.
Ok, so more droop for bumpy or slippery conditions? Less droop for smooth and grippy conditions?
So if my traction is bad, I should use more droop? So droop is the amount of travel the a-arms move?
Thanks!!
-KS
Thanks!!
-KS
yes
knightshift- droop is the down travel of the arms. In other words, as you lift the chassis of your car up, it is the amount of travel before the tires come off the ground. If the car sits at ride height, and you lift the back end of the chassis, and the tires leave the ground when you lifted the car 5mm past ride height, you have 5mm droop. Droop lets the chassis roll around and it lets the wheels drop down into imperfections in the track.
I brought my '04 to fit for 48p gears today and the LHS dude checked out my car. He told me that my car had waay too much droop, and recommended that any car should have at most 7mm of droop. What's this about? 'cause I more or less have my car dialed for my "hometrack" and any less droop will have my car sliding around.
Thanks.
Thanks.
Thanks.
Thanks.
What dtm said
Thanks DTM & Yokomo Fan!
Alvin if you're using the factory setting on the 04R, then you would see the rear has a lot of droop. if you use like a 5mm spacers(outter) on the shock, the springs won't even touch it if you lift it off the ground.
I'm planning on getting the AE droop gauge so how do you use it?
Alvin,
If your car handles OK then don't worry.
Basicly, if you run on a low grip surface then more droop = more traction. I had a hell of a game diallling in my TC3 to our slippery track. A fast guy told me to remove all the shock limiters and, hey presto!! dialled car.
I don't know what the actual droop is but I don't care, it works. I think diffferent cars work to different tollerences.
Yorkie
Yorkie
I have the AE one, and the blue aluminum yok one which has both droop and ride height.
Speedo
