Old 05-14-2008, 11:35 PM   #1
Francis M.'s Avatar
Default Brushless Gurus
Now that the weather is getting warmer. I'm paranoid about burning up my motor. I want to place an external fan but I'm not sure If I point it in the middle of the can or towards the rear of the motor......
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 05-14-2008, 11:43 PM   #2
my guess would be across the top if the motor to help keep the can cooler .. or even try a motor heat sink with a fan mount .. I myself have never had much luck with heat sinks . to me they retain too much heat and cause problems ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 05-15-2008, 12:02 AM   #3
syndr0me's Avatar
Trader Rating: 32 (100%+)
What brand of motor?
syndr0me is offline   Reply With Quote
Old 05-15-2008, 03:26 AM   #4
My opinion is even you put 10 fans but with the wrong gear ratio, the brushless motor will just gone over heating internally...
I have seen brushless motor gone even with low temp at motor casing temp approx 60-70deg C measured with the temp gun, not sure temp inside the motor...
I still trying to master the art of gearing the brushless.. any rule of thumbs to help??? i.e., shall we gear the same running with 5 cells 3.5T with 6 cells 4.5T with 6 cells 7T brushed....
MARKANO is offline   Reply With Quote
Old 05-15-2008, 09:09 AM   #5
Francis M.'s Avatar
I've been running the Novak and Orion 10.5 motors with LRP speedo
I don't really have a problem with the Novak it's more with the Orion that seems to build heat....
Old 05-15-2008, 09:18 AM   #6
syndr0me's Avatar
Ah, okay. I'm not sure how well fans work on BL motors, but Novak's heatsink (that replaces the center ring) seems to work amazingly well if you ever have heat problems with that motor. I don't know if it will fit on the Orion's stator.
Old 05-15-2008, 09:19 AM   #7
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
they will fit you just have to shave some material off the inside of the ring (not much)
I need your help [Buggy Gurus] Jim Bob Nitro Off-Road 30 07-05-2008 11:41 PM
engine gurus please help Gen Nitro Off-Road 5 01-01-2008 11:43 AM
Question for shock gurus Lumens Rookie Zone 2 11-13-2007 06:45 PM
Hi Gurus~ TZR250 Singapore R/C Racers 2 07-15-2007 11:14 PM
Motor gurus ? rai13 Electric Off-Road 3 12-20-2005 06:46 PM
