Old 01-03-2002, 04:22 AM   #1
Regional Moderator
disaster999's Avatar
Default Motor RPM
hey...i was wondering what rpm range goes for different turns or motor.
whats the rpm of a 12t, 10t, and 9t motor?
thanks!
disaster999 is offline   Reply With Quote
Old 01-03-2002, 07:24 AM   #2
Regional Moderator
daniz24's Avatar
My Evo4 8T : 48500 RPM
daniz24 is offline   Reply With Quote
Old 01-03-2002, 07:51 AM   #3
MissX's Avatar
My Yokomo SZero 9T3 has 46.500 rpm
www.courtneyday.com
MissX is offline   Reply With Quote
Old 01-03-2002, 08:20 AM   #4
Regional Moderator
what about yokomo 12x2?
you know the rpm for it? approximatly?
Old 01-03-2002, 08:41 AM   #5
Regional Moderator
daniz24's Avatar
it's about 37000-40000 maybe
Old 01-03-2002, 08:54 AM   #6
Regional Moderator
oh...soso...for 10t...its about 42000-45000....and for a 9t is 45000-48000...??
Old 01-03-2002, 01:00 PM   #7
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
For touring cars RPM hardly matters at all What you should be asking is the power and torque numbers.
Speedo is offline   Reply With Quote
Old 01-03-2002, 01:08 PM   #8
Those ratings are with a no load max RPM rating. I would imagine that a motor with a noticeable amount more of torque but with a lower no load max rpm should be able to maintain a higher rpm with a load put on it due to the higher amount of torque giving the motor more power as per say. Therefore actually giving it a higher speed than a high rpm motor with low torque when both have the load of a cars drivetrain that it has to lug, unless you are using a pan car which will have far less drivetrain lag. I could be wrong though, but it sounds logical, lol.
WailinOnYa is offline   Reply With Quote
Old 01-03-2002, 02:44 PM   #9
Moderator
Speedo's Avatar
No, those have to be dyno numbers, in which case there is a load. In the case of a flywheel dyno, eg robi, it is the flywheel and on a dyno like the CE it is the slave motor. But as Big Jim says, power is RPM*torque, and even a small increase in torque is enough to compensate for a loss in RPM. I don't really even look at RPM. First I look at power in a certain load range, then at max power, then at torque, then spinup time.
Old 01-03-2002, 08:02 PM   #10
Regional Moderator
thanks for the input! i wanted to know the rpm of the motor because i want to find out how fast my car would go!!
Old 01-03-2002, 08:16 PM   #11
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
depends disaster
a FURY 10x3 gives around 58000 rpm
after thinkering here and there but ... u will need 9:1 gearing and higher to make it work COOL .... or else ... u can easilly place a pan over the motor and cook an egg there LOL
but battry wires get super and solder joints might melt off and ....tires + belt never lasts
and .... according to a local experianced racer there he says the dyno might be wrong or might be faulty .... but hey its the fastest motor on the track ....
hehe ever seen a battry pack sorted out after the solder joints melted on it .... happened when i used this motor ...
and its 60.40 solder
sold this motor to someone and he retired it ... after breaking his pro 2 LOL
HAHAHAHHAH guess how much i sold the motor ... second hand ... USD 80 he offered me 50 i did not want to sell and he raised the price to 80 .... and its just too tempting ... got a 13x3 with the money and the rpm is at around 39000 rpm
imataquito is offline   Reply With Quote
Old 01-03-2002, 08:36 PM   #12
Regional Moderator
daniz24's Avatar
[QUOTE]Originally posted by imataquito
[B]depends disaster
QUOTE]
I think your motor is over-timing..... 10T should be around 45000-48000 rpm....
Old 01-03-2002, 11:45 PM   #13
Alvin's Avatar
Dudes, what's the difference between a Motor Dyno (e.g Robotronics) versus "Motor Dressers" and "Motor Checker" e.g. , SpeedPro, Team Orion
Thanks.
Alvin is offline   Reply With Quote
Old 01-03-2002, 11:46 PM   #14
imataquito's Avatar
timing is set to 4-5 on the end bell to can part
Old 01-04-2002, 12:31 AM   #15
Speedo: Yeah you have a point there, but Trinity put out max RPM numbers on their motors even before there was such a thing as an electric motor dyno! Now I don't know if they had a custom built machine that they used to get these numbers or if they were just using a Tach with a given voltage to get the readings or not but even a flywheel on a dyno is far from a close realistic figure compared to being in an actual car with all the driveline drag, resistance and friction. Now that I say this I am kinda curious how they got these #'s way back when! Dynos are a pointer to which motor will be better suited to it's use, which in turn also relates to in car use, a better motor is a better motor, but the flywheel readings would still be drastically different than what will be achieved in the car itself, if it were possible to measure it there.
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
FS/FT NIB LRP 5.5T Brushless motor/ Castle CM-2080 motor Trade for Newer FUTABA S9451 ffpm46 R/C Items: For Sale/Trade 13 03-31-2008 02:17 PM
Modify your stock motor, mod motor, any motor! TRF-Powered Electric On-Road 10 03-15-2007 05:52 PM
Trinity Motor Checker “Monster Horsepower Machine” Motor Performance Monitor CRiXman R/C Items: For Sale/Trade 5 01-25-2007 03:36 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
