Old 05-13-2008, 07:31 AM   #1
fly_wheel's Avatar
Default HELP: NOSRAM Matrix Brushless ESC + 3PK setting
i have a nosram matrix brushless ESC n a brush motor Katana 23T stock with 3PK tx. the problem is, i can't get the ESC to work correctly. it seems like the trottle trigger has been reversed. i mean, a slight pull on trigger from neutral, the motor will work at full speed n when pulling full on trigger will cause it to slow down... brake ain't working as well... anyone has any idea? is ther anything i need to set on the tx or esc???
another Q, the esc stated it support over 5.5 turn brushless... is that means it can support 5.5 n over or only 6.5 n above???
thanks in advance...
fly_wheel is offline   Reply With Quote
Old 05-13-2008, 07:58 AM   #2
MikeXray's Avatar
Trader Rating: 73 (100%+)
Did you resetup the speed controller once installed, do you have the throttle reversed in the radio?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 05-13-2008, 08:47 AM   #3
bs6ef's Avatar
Mate if you follow your setup instructions for the nosram esc, i.e. how to setup the esc to your hand set and make sure the throttle on the hand set isn't reversed to what it should be then you will not have any more problems.
You have to watch the TechnoViking http://www.youtube.com/watch?v=_1nzEFMjkI4
bs6ef is offline   Reply With Quote
Old 05-14-2008, 09:33 AM   #4
fly_wheel's Avatar
i just got confirmation from the nosram dealer that my ESC is faulty
although it has lifetime warranty but it'll cost me upto 6 months for a replacement or repair... anyway, thanks for all the helps...
Help nosram matrix evo 07 benste Singapore R/C Racers 1 03-10-2008 12:12 AM
Nosram Matrix ( Where to buy ) A Ilievski Australian Racing 12 01-10-2007 12:17 AM
Nosram Matrix ( Where to buy ) A Ilievski Electric On-Road 0 01-06-2007 05:54 AM
Nosram Matrix & LRP Sphere N15M0 Rookie Zone 1 10-24-2005 12:52 PM
Nosram Matrix and Storm Brushless System centax error! Electric On-Road 2 07-21-2005 11:29 AM
