C'mon guys, take the Trans Am survey, no personal info required . . . >
Old 05-08-2008, 08:46 PM
boscoj's Avatar
Default C'mon guys, take the Trans Am survey, no personal info required . . .
C'mon guys, take the survey, no personal info required . . .
http://www.surveymonkey.com/s.aspx?s...VUY396dw_3d_3d
boscoj is offline
Old 05-09-2008, 01:34 AM
Ike
Ike's Avatar
Kinda flawed since after you answer no for the first one you have to answer all the other questions which don't really apply... After I found that out I closed the window. I would suspect that most others that don't want the class will do the same.
Ike is offline
Old 05-09-2008, 07:56 AM
boscoj's Avatar
Okay should be fixed. only my second time using this thing . . .
boscoj is offline
