Old 07-30-2003, 07:27 AM   #1
Default LRP IPC V7.1 Digital Pro Speed Control
What is the best setup of the LRP V7.1 for stock and modified?
Raikonnen is offline   Reply With Quote
Old 07-30-2003, 07:41 AM   #2
kt racing's Avatar
Send a message via AIM to kt racing
novak GT-7
The cases on the LRP break open and the speedo burns up
kt racing is offline   Reply With Quote
Old 07-30-2003, 07:48 AM   #3
The case can be protected (I think) and why do they burn? Did you ever have an LRP?
Old 07-30-2003, 07:51 AM   #4
kt racing's Avatar
yes I have had two of them. The cases on both of them broke open. That is why they are coming out with new versions of them but I also didn't have very good luck with the company fixing them. They are very slow and rude. And as far as burning up. if the inside comes out of the case there are tons of things on the car for it to short out on. Not saying it will short out. But the case will come apart on you the first time you hit something hard.
Old 07-30-2003, 07:55 AM   #5
I appreciate your comments ... but now I have one can you give me suggestions how to set it up for Stock racing
Old 07-30-2003, 11:19 AM   #6
Cole Trickle's Avatar
Originally posted by kt tracing
...But the case will come apart on you the first time you hit something hard.
Yep they come apart from time to time. But not THAT easy... Mine haven't shortend. Besides a small drop of glue prevent it from open up accidently.
Setup fot stock? Depends on traction. If you got plenty of traction, dont even consider current limiting. Personally I prefer to disable the auto brake, since a stock motor in it self brakes a lot.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-30-2003, 12:52 PM   #7
CGR
CGR's Avatar
I had a few LRPs. I put the sticker aroudn the seam like they say and never came open and always worked. I sold them though as I like the GT7 beter.
CGR is offline   Reply With Quote
Old 07-30-2003, 01:54 PM   #8
Mr. MR4's Avatar
Hey Raikonnen,
I never had any problems with the 7.1 except for the case coming apart - just put some tape around the case to prevent this.
For Stock try the 50A or 65A Chip.
I use mine on 50A (3) for stock
Hope this helps.
Mr. MR4 is offline   Reply With Quote
Old 08-02-2003, 01:53 AM   #9
Is there any other guys who have experience with the LRP V7.1? How can you get the best punch for a Stock Motor?
Old 08-02-2003, 11:42 AM   #10
It's made for modified, so there's only a few things to do:
1: Set it for maximum current, that is, no limiter. Remove the chip. If you dont want the hole from the chip, use the 120 A limiter, which wont limit a stock motor.
2: If your TX is programmable, set the throttle curve with a little off-set, that is, so the starting current is a little higher. On my KO Presto, I've set it for +20 (the range is 0-100, maybe 120).
This way it works fine for me.
Old 08-02-2003, 12:41 PM   #11
The V7.1 also has a "jump start" feature. Before the start of the race hold the brake on and count to 10. The next time you pull the throttle it will go to 100% with only 50% of the throttle pull. First time you back off it shuts the feature off until you go thru the 10 count deal again. Sometimes this will give you a little edge getting off the line.
calvin is offline   Reply With Quote
f/s digital speed control downunder23 R/C Items: Wanted to Buy 1 10-24-2006 11:19 AM
LRP digital speed control, IPC Pro Sport, No Motor Limit! sjc115 R/C Items: For Sale/Trade 3 02-21-2006 05:00 AM
Brand New LRP IPC Sport Digital Speed Control RCNitroDude999 R/C Items: For Sale/Trade 2 11-17-2004 09:27 PM
LRP IPC Pro Sport Digital ESC, Speedo, Speed Control etzkev R/C Items: For Sale/Trade 11 09-08-2004 08:28 PM
***Keyence Zero-V Extreme Digital Speed Control*** Dave Kurschner R/C Items: For Sale/Trade 3 01-07-2003 11:05 PM
