Old 08-27-2008, 01:34 AM   #31
adrictan's Avatar
I was told the TRF415 spool is the same as the Evo IV one.#49358. Anyone can confirm this?
adrictan is offline   Reply With Quote
Old 08-27-2008, 02:19 AM   #32
On the spool problem, wouldnt it be possible to convert the rear diff into a spool. i did this on the old yokomo sd with abit of shimming and it worked great in stock and 19t with none of the chatter you get with a steel spool and it also gives a bit of slip in a crash. just leave the balls out and get rid of the grease
Gray is offline   Reply With Quote
Old 08-27-2008, 02:27 AM   #33
In what situation would you want a spool at the rear?
stocker is offline   Reply With Quote
Old 08-27-2008, 02:34 AM   #34
suking's Avatar
Send a message via MSN to suking Send a message via Yahoo to suking Send a message via Skype™ to suking
Originally Posted by Victor A View Post
Source: www.rctouring.eu Direct link to article: http://rctouring.eu/tamiya_tb_evolution_v_ms.htm
I'm really curious about this car. I really loved my TC3's... the good old days . Does anyone know the internal ratio of this car?
Thanks Victor
Originally Posted by rctouringracer View Post
Noticed some of you guys run the tb02, Is there a spool that will fit in the tb02 & tb02r?
just fllow your hobby is ok .don't care which one is the most popular.......
RC 4 U........
http://www.henergy-battery.com
suking is offline   Reply With Quote
Old 08-27-2008, 02:51 AM   #35
adrictan's Avatar
If use the ball diff but remove the balls, i need to superglue the lock nots so it won't slip right? That's the alternative way if I can't get the spool.
Old 08-27-2008, 05:39 AM   #36
You shouldnt need to use superglue, just tighten the diff screw quite tight, but not too tight that you break it.
Old 08-27-2008, 05:43 AM   #37
Old 08-28-2008, 05:03 AM   #38
adrictan's Avatar
Unfortunately, whenever I tighten it, it'll slip after a few times.
Old 08-28-2008, 09:20 AM   #39
Trader Rating: 30 (100%+)
Rather than use superglue, you might want to try shoo goo since it can be removed.
wrxnfx is offline   Reply With Quote
Old 09-18-2008, 06:36 PM   #40
Juanchoyo's Avatar
Hi guys, where can I get the manual for the MS??? I found the Evo V 50000 times but it seems no one has uploaded the manual for the MS..... Do you know where can I get it???? Thanks!
FoxRC Hobby Club
http://foxrc.foroactivo.net/
"Mas que un hobby, un estilo de vida. Algo que corre en los circuitos de mis venas"
.....ChOoJuAaAnNnn, Sebastian, Juancho... como quieran XD.... o Sebastian Oviedooo...
Juanchoyo is offline   Reply With Quote
Old 09-18-2008, 06:55 PM   #41
here?
Old 11-07-2008, 03:47 PM   #42
Juanchoyo's Avatar
Default Help with Main Shaft and Spur Gear
Hi guys... im helping a friend of mine to find an answer to his problem... His car has thes two problems...
1. The shaft has a lot of free-play moving front to rear... that creates a louuud noise when going fast!!
2. His spur gear touches a lil of the top deck....
The video shows it all.... Its in Spanish but u can see everything in there....
Could someone download it and gimme a hand??? He shows some fixes but nothing that really convinces us to fix the spur problem.
Any suggestionS???????
http://www.clubrccaceres.com/SOCIOS/...5/Problema.avi
Thanks a lot guys!!
FoxRC Hobby Club
Old 12-14-2008, 07:25 AM   #43
adrictan's Avatar
So has so far anyone tried fitting the EVO IV Spool #49359 to the EVO V MS?
Old 12-14-2008, 08:52 AM   #44
It is not compatible 'as is'. Better choice is to buy a 3Racing Spool for Tamiya TB03 - it has a perfect fit (note: it uses differential gear instead of one-way gear).
TommyW is offline   Reply With Quote
Old 12-14-2008, 08:57 AM   #45
adrictan's Avatar
Sorry, I'm not sure what u meant in yr note. Explain? Thanks.
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
