Old 08-23-2009, 04:36 PM   #136
Callahan_88's Avatar
Is the Evo 5 discontinued and replaced by the Evo 5 MS?
Can´t find the thread about the Evo 5.
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-24-2009, 01:58 PM   #137
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
According to Tamiya's website the Evo 5 has been discontinued. Evo 5 MS is still current.
Steve
ALL TAMIYA 4 WHEEL DRIVE ALL THE TIME
TRF-416X, SP CIRTIX, LRP X-12 17.5, FUTABA 9550
SRBMOJO is offline   Reply With Quote
Old 08-31-2009, 04:06 PM   #138
YDBD's Avatar
Send a message via MSN to YDBD
Default Evo Wobble?
Ok, just picked up my Evo 5 MS from the LHS here on Okinawa. (gotta REALLY good deal)
I'll be running in the 23T class here, but have some wobble issues...
The assembly went as norm for a Tamiya, a little from this bag, a little from that bag...when will they put the parts in the same bag for the same assembly???
On to the problem...
When going SLOW at about 6 feet the chassis rear end kicks over like the toe or tracking is off and does about every few feet after that. It's got a definite wobble somewheres.
What I've tried:
  1. Added more front toe
  2. Changed tires
  3. Rechecked all arms with digital calipers to specs
  4. Pushed the chassis with no pinion
  5. Took it back to the LHS, both guys tried, said maybe more front toe but that's all.
  6. Rechecked all spacers on hinge pins.
What may be wrong:
The rear hinge pin mount bound a bit on the left side, it looks like the mount may be over to the right about .25mm but I can't find a good way to get a calliper on it and why would it be off?
The ball diff needs to be broken in?
Next step is to actually spend the money for some set up wheels and board to check everything....$$
Any ideas?
Jon
RC and Beer Brewer
the only way to DUI!
YDBD is offline   Reply With Quote
Old 08-31-2009, 08:41 PM   #139
I suspect that there's a kink in the drivetrain.
Here's my suggestion;
1. Remove the motor from the drivetrain.
2. Remove all wheels.
3. Turn the spur with your fingers very lightly. As you turn, feel for resistance as you go around.
4. Do you hear any ticking sound?
5. Do you feel the drivetrain/spur sticks at certain areas and frees itself again?
6. If you answer yes to any of the above, then, it means that the spur adapter versus the the alignment of the rest of the drivetrain is off.
7. Loosen the 2 screws on the motor mount.
8. Loosen the 4 screws that secures the alloy plate that sits over the spur gear.
9. Spin the spur to free the area and hoping it will get into alignment.
10. Carefully screw down the 4 screws of the alloy plate.(taking care not to tweak the area)
11. After tightening, flip around and tighten up the motor mount. This should straighten it up.
12. Turn the spur again. It should have removed the ticking sound or kink.
I think try that first. If it does not solve the issue, then maybe a kink in the UJs, seizure of a bearing....? Good luck!
Cheers!!
What I've tried:
  2. Changed tires
What may be wrong:
Any ideas?
K.I.S.S.
Keep It Simple Stupid
kerk is offline   Reply With Quote
Old 08-31-2009, 10:21 PM   #140
YDBD's Avatar
Thanks Kerk, already checked the drive shaft, bearings, bulk heads. Everything spins very smooth of the ground, tires, no tires, pinion or no pinion. So apparently that's not the issue.
Guess I'm off to get set up wheels and a board....
Jon
RC and Beer Brewer
Old 09-01-2009, 09:03 PM   #141
Smile EVO V
evo 5 MS is nor different to the V. only upgraded is the upper deck!!
haha.. which i have already done ages ago before they came up with this...
drifter24 is offline   Reply With Quote
Old 09-01-2009, 09:12 PM   #142
Thumbs up evo 5 spool
Originally Posted by rctouringracer View Post
Do ya'll at least think maybe Tamiya will release a spool to go along with list version of the EVO?....
i've got an evo 5 spool in mine.. that thing was every rare to find.
Old 09-01-2009, 09:14 PM   #143
Timmie's Avatar
I think you are saying the evo5MS is not different to the evo5, but there is quite a few differences between the two. I don't want anyone getting mixed up looking for certain parts on these cars.
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 09-01-2009, 09:18 PM   #144
Timmie's Avatar
The spool to use is Tamiya #54125 TB-03 Direct coupling set. evo5/MS/TB-03 share these drivetrain parts.
Old 09-02-2009, 02:08 AM   #145
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
I'm using that spool right now in my Evo IVMS. Just an fyi...
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 09-13-2009, 10:11 PM   #146
Default spur fitting
Originally Posted by C van der Hagen View Post
does a 87/47 (64dp) fits the evo 5 MS?
hey man. i have evo 5 (not MS) i use a 102T (64dp) just had to shave a 1mm off the upper deck and i cant see why a 87T cant fit..
im waiting for evo5MS parts to be released so i can rebuild me evo to MS.. there isnt much that was done to the MS. LOL
Old 09-13-2009, 10:16 PM   #147
Post
yes, these two arnt different from far... if evo 5MS parts do come out or if they have already... and partss should easily fit to it. since there not far from the design!
Old 09-13-2009, 10:36 PM   #148
Hebiki's Avatar
Trader Rating: 26 (100%+)
um.. these two cars are VERY different. i know. ive owned BOTH cars.
the entire rear part of the drivetrain is different. from the input shafts, and motor mount. not to mention the upper deck and steering system.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-13-2009, 10:58 PM   #149
Hebiki's Avatar
Default Rear spur gear assembly comparison
here are images from the instructional manual. shows the differences between the two cars.
evo V
evo V MS
Hebiki Design Works
Old 09-13-2009, 11:10 PM   #150
superspeed's Avatar
wonder if evo v ms will be disc soon as well since it's on sale for around $350 now.
superspeed is offline   Reply With Quote
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
FS: Tamiya TB Evolution II (NEW) ivan3721 R/C Items: For Sale/Trade 1 05-18-2008 05:56 PM
FS: Tamiya TB Evolution 5 veecee Australia For Sale/Trade 3 07-20-2007 08:13 PM
tamiya tb evolution 5 b-man777 Electric On-Road 1 05-24-2006 11:38 AM
XXX-S GP VS Tamiya Evolution III capricess Electric On-Road 29 01-27-2003 08:49 AM
