Old 05-10-2008, 12:32 AM   #16
Suspended
here's a pic of my X-Ray T2 with a Yeah Racing 3200 lipo in it. It fits perfectly without any modifications. You just have to slide it in an angle and it will snap right in.
Should work the same way for the Orion Carbon 3200 since it is the same pack as the Yeah Racing 3200....'except the Yeah Racing pack is only $40
403forbidden is offline   Reply With Quote
Old 05-10-2008, 05:28 AM   #17
iixliltonyx33's Avatar
Send a message via AIM to iixliltonyx33
to fit the 3600 hundred just dremel that lump for the sub cs with a cutting wheel or you can send it to me and i cnc it off
Tony
Team Driver for TNT Racing and Scuba Steve Graphixs
360 rc speedway and hobbies, Willis Hobbies
iixliltonyx33 is offline   Reply With Quote
Old 05-10-2008, 06:22 AM   #18
FOXY923's Avatar
Originally Posted by trailranger View Post
LiPO Fitment Thread
I think the answer is yes
Thanks. I'm getting the Orion 3600 pack now though so I'll have to dremel the bulkhead.
Thanks for the offer. I'll try it myself first so I can run it without the wait.
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 05-31-2008, 05:32 PM   #19
FOXY923's Avatar
Here is my Orion 3600 in my T2. Fits nice & tight.
Now I just need to figure out how to get the - wire plugged in. I'm thinking I'll have to solder the wire onto the plug sideways. Anybody else have to do that?
RACE 4FUN
Old 05-31-2008, 06:08 PM   #20
MaxSp97's Avatar
Foxy,
I added the washer "1-2mm" under the battery strap posts. This will keep the battery strap flat NOT bow. This will eliminate the chassis tweak.
Battery plugs I soldered straight, side way is hard to disconnect.
MaxSp97 is offline   Reply With Quote
Old 05-31-2008, 09:18 PM   #21
FOXY923's Avatar
Originally Posted by MaxSp97 View Post
Foxy,
Yeah I was just about to add a washer. I wasn't thrilled with the bow of the brace.
With the plug straight will it fit under the top deck? I haven't tried my let but I'm not sure it will fit Looks like it'll be a tight fit for sure. I was thinking if I bent the wire after striping it I could solder it onto the plug. I thought this would give me that small area to use to grip to remove from the pack. I'll try what I have now and go from there.
RACE 4FUN
Old 05-31-2008, 09:19 PM   #22
GreaseMonkey's Avatar
Turn the battery around so the terminals are towards the back.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 05-31-2008, 09:21 PM   #23
FOXY923's Avatar
That was on my list of things to try. Thanks for making me feel like I'm not an idiot...sorry if this sounds sarcastic it really isn't...really. I'm a total noob when it comes to lipo. I have read a bunch about them, charging etc, but mounting in a car is new.
RACE 4FUN
Old 05-31-2008, 09:38 PM   #24
You're not the first person I've seen put the battery at the front and then wonder how to get the negative terminal to work. I guess people's natural instinct is to move the terminal away from the spur gear. Anyway, I had mine to the rear and it worked fine. The positive terminal was fairly close to the bulkhead but never touched it.
Old 05-31-2008, 10:45 PM   #25
FOXY923's Avatar
Yup, I'm going with the terminals towards the rear. Looks like everything will clear just fine. I also added a washer to raise the battery brace and that is perfect. I am now a "Lipo Lover"
Now I just need to add some weight Any idea how much I need? Keeping in mind I'm using this pack in my T4 as well, so adding weight directly on the pack is not going to work. Even if I have to add some to the battery brace that would be fine. I'm not is serious contention for the A main so keeping the CG below the chassis isn't an issue
Edit: GreaseMonkey, I just noticed your from Ottawa...nice knowing I don't 'need' to travel south of the boarder for help, eh.
RACE 4FUN
Old 05-31-2008, 11:26 PM   #26
For weights, one of our racers got a steel key and cut it down. He then drilled and tapped it so he could screw it to the chassis. I tried to find the pics on our old forum but couldn't. They might be in the T2 thread here though.
Edit: this should work: http://www.rctech.net/forum/showthre...65#post3521765
Old 05-31-2008, 11:39 PM   #27
FOXY923's Avatar
Thanks for the link. I couldn't find it. I must be tired cause I read "steel key" and though, "ok, I have a bunch of key's I don't know what they unlock". I'm going to bed now.
Thanks for the tips. Any idea how much weight that is? or how much I may need to add? If I had a scale I wouldn't have to ask
RACE 4FUN
Old 06-02-2008, 07:26 AM   #28
FOXY923's Avatar
never mind
RACE 4FUN
Orion advantage carbon edition charger + Orion 3200 spec LiPo $150.00 vintagetamiya R/C Items: For Sale/Trade 9 04-09-2008 05:05 PM
Orion 3200 7.4v Carbon lipo yyhayyim R/C Items: For Sale/Trade 0 01-13-2008 05:23 PM
Orion Carbon 3200 Lipo gearhead R/C Items: For Sale/Trade 15 01-10-2008 03:34 PM
Orion 3200 Carbon Lipo Must Go CorallyBQuiK R/C Items: For Sale/Trade 2 12-19-2007 10:34 PM
Orion 3200 Carbon lipo wikedgmc R/C Items: For Sale/Trade 3 12-01-2007 12:01 AM
