Old 05-03-2008, 05:55 AM   #1
Default FDR on Touring.
Hello.
I am new to brushless systems and wanted to ask whats the best FDR range for 13.5 novak system GTB/13.5 Sport or something. I have to make an order for pinions and spur gear because i am not able to buy almost anything on the spot. Track is quite large. Here is pic. http://www.rcdrift.lv/atteli/rakstiem/placis_04a.jpg not drifting but touring car racing, picture is hosted on the server. Thanks.
Logika is offline   Reply With Quote
Old 05-03-2008, 06:20 AM   #2
For a large asphalt track like you have pictured, you will probably be in the 4.6 - 4.8 FDR range. It looks similar in size to what we run on in Tacoma Washington. Start with 4.8 and temp your motor after about 5 laps. It should not exceed 160 degrees F. This is assuming that you are using the Novak 13.5 with a 12.3 mm sintered rotor.
Pete
Pete Thomas is offline   Reply With Quote
Old 05-03-2008, 06:35 AM   #3
If internal gear ratio is 2 then the pinion and spur ratio should be 2.4 for FDR to be 4.8. spur somewhere 70 and pinion 29 at 48p. DO they even make 70t spurs? Or should i try 78t spur and some 33t pinion?
Old 05-04-2008, 07:27 AM   #4
sandrixx's Avatar
Default yup
Senyor Logika, yes they do make 48p 70t spurs. try kawada or robinson racing. So how's the performance of the NOVAK 13.5 BL motor?.. fast/quick enough?...
Team DogBone-Cobra/Serpent
Team F.R.E.A.K.S/SOLIDSNAKE_Saudi Arabia
Stay Serpent...
sandrixx is offline   Reply With Quote
WTB:touring car Snipesr82 R/C Items: Wanted to Buy 6 06-22-2008 11:03 AM
FT: xxx-nt, bmi tc3 -looking for 1/12 or other touring tc3Guru R/C Items: For Sale/Trade 1 11-27-2005 03:38 AM
Touring Shumacher 99 Nitro On-Road 7 10-20-2004 12:18 PM
OB4 touring car 3derwood R/C Items: For Sale/Trade 2 03-20-2004 02:11 PM
Nitro touring for electric touring iflybyu R/C Items: For Sale/Trade 1 09-28-2003 11:44 PM
