Old 10-04-2009, 08:27 AM   #466
Yeti35's Avatar
I am not sure you can down grade, but since we don't really have an Xcelorin tech on the thread anymore it is really hard to say.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-15-2009, 10:33 AM   #467
cla5675's Avatar
Trader Rating: 49 (100%+)
Default Xcelorin S w/ 1s and 13.5 in WGT
Hey, all. I hadn't seen anything on using a single cell pack with the Xcelorin S so I decided to try it out last night and it works when used in conjuction with a receiver pack. I was running a CRC Gen X10, Thunder Power 1s 5000 40C pack, Novak 13.5 motor, 180mah 7.4v rx pack and Spektrum reciever. I had to try a few different scenarios to get it all to work correctly but I found what worked for me. You need to first plug in (or turn on) your reciever pack then plug in the single cell battery and leave the ESC switched off. I was able to run 6-minutes heats very easily this way. Now I need to do some fine tunning on the roll out as well as the ESC settings. I'll keep posting what I find with different setups/changes....if any one cares.
cla5675 is offline   Reply With Quote
Old 10-15-2009, 11:03 AM   #468
Casper's Avatar
Trader Rating: 34 (100%+)
I have been running my senesored xcelorin system in my CRC Gen X 12th for a while now. I use the novak booster instead of the reciever pack though. Works great. I have the 4 cell plate on the speedo as well to reduce wieght and height of the speedo.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-15-2009, 02:21 PM   #469
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Any new updates on the Xcelorin ESC software? I have a used one that I am going to put on my Type R and enter it in the 13.5 novice class at Speedworld as soon as I can get some track time under my belt. I would like to be able to keep up and not get blasted by the Tekin or LRP esc's
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 10-15-2009, 02:30 PM   #470
Rasheed's Avatar
I care. I will probably be running a 1 cell/13.5 or 1 cell 10.5 setup this winter in a WGT car. Keep us posted!
I emailed losi this exact question about 2 weeks ago and they replied saying "at this point there is no plan to add those features to the xcelorin". I think if I get into onroad more I will just go ahead and buy a tekin. However, in the novice class i'm sure that driving will be a much bigger issue than the speed control. I'll use my losi for offroad, where I usually run mod.
Derek "The Speed" Rasheed - Sponsored by Kaiser Permanente. Thrive!
davesrctracks.net - a great offroad 1/10th scale track.
Rasheed is offline   Reply With Quote
Old 10-15-2009, 03:08 PM   #471
dfiantii's Avatar
I have a speedpassion GT2.0 for my Corally RDX that I am going to put in the RCGT 17.5 Class and the Losi Type R with Losi ESC for 13.5. If i am not keeping up I maybe eventually get the SP GT for the 13.5 or maybe upgrade to Tekin RS. I doubt I would need the RS Pro since I will never run Mod Class.
TLR 22 2.0
Old 10-15-2009, 03:58 PM   #472
Casper's Avatar
For offroad I had done really well with my xcelorin speedo's keeping up with the LRP's and tekins in 13.5. They have just a little more top speed then I do but I have way more punch on the infield.
In my 12th scale though I can keep up in the infield but I loose them on the straights. For novice you will be just fine with the xcelorin. Keep it off the boards and you will do fine. Once you start playing at the upper levels speed will matter more.
Old 10-22-2009, 09:25 AM   #473
cla5675's Avatar
Default WGT Update!
Hey, all. Got to run the Gen X10, Xcelorin, single cell combo again last night. However, I forgot the laptop again so I was stuck with tuning via the QPC card....which has it's limits. Anyway, the car ran better and I'm still sneaking up on the correct roll out. Also, I started noticing a slight "delay" with the throttle later in the run, but I think my rx pack was running low which may have some how effected the throttle response. I can't even remember if I charged the rx pack last night!! Anyway, testing is still going well and I hope to bring home a win soon!! Later!!
Old 11-16-2009, 12:07 PM   #474
CL
CL's Avatar
Trader Rating: 32 (100%+)
Can the timing be change on the Losi brushless motor?
More racing and less typing!
CL is offline   Reply With Quote
Old 11-16-2009, 01:34 PM   #475
Casper's Avatar
No. The timing is fixed on the motor.
Old 12-13-2009, 04:54 AM   #476
Trader Rating: 114 (100%+)
LOSI - please give us a "turbo timing" update to our firmware!
Chris Furman is offline   Reply With Quote
Old 12-13-2009, 05:48 AM   #477
jrxs-r's Avatar
yeah.... that would be nice... I have since relegated that Xcelorin to my 2WD off road chassis as it simply can't keep up with the current generation of ESCs. Need stronger and less-fade brakes and more timing options.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 12-13-2009, 05:26 PM   #478
oeoeo327's Avatar
Trader Rating: 74 (100%+)
I was able to adjust the timing on my Losi 17.5 motor, but the timing ring has a tendency to "stick" on newer motors. I freed the timing ring by running a fresh X-Acto blade CAREFULLY between the motor can and the timing ring.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 12-13-2009, 05:46 PM   #479
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
lol
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 12-13-2009, 10:04 PM   #480
Casper's Avatar
Timing advance is really only something you need in onroad. I have been racing against timing advance guys for a while in offroad and don't feel at a disadvantage at all. When I had my 12th scale though a totally different feeling. Wish I had it.
I know losi is looking into new stuff including timing advance as they are always in develpment but nothing I know of that is imminent. In the mean time I am still extremely please with my xcelorin equipment in my offroad cars.
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
