Old 12-24-2008, 05:09 AM   #301
Joel Lagace's Avatar
To get software installed on VISTA:
-Log into ADMIN (not your user name with full admin prevliges)
-If you cant see ADMIN log on see below*****
-Disable antivirus (in the case of AVG i had to uninstall it completely first)otherwise the install will fail.
-Install software
-plug in USB adaptor. ITs red led is on. If drivers dont load go to device manager.
-From Device manager click usb adaptor and install drivers. Point it to your C:\Program Files\Losi\Drivers folder
-it should install without issue
-USB should now turn green
-Start up software. GREEN light should be lit for usb
-plug in ESC(no battery hooked up at all!!) and software should turn green and show you your esc settings
-program away, this software unlocks way more features then the setup card
CANT FIND ADMIN?:
Follow simple instructions found here
http://www.howtogeek.com/howto/windo...-windows-vista
UPDATE:
Losi site for some reason does not have the file. But its attached to this post. The lastest firm ware is:
D.11.01.25
email me for file if you need it, Losi site is FUBAR cant download from there from any of my browsers
MERRY CHRISTMAS
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-24-2008, 07:03 AM   #302
sb7979's Avatar
Trader Rating: 36 (100%+)
That's great info Joel, however I need drivers for 64 bit Vista. Nothing that came on the disc seems to work.
Anyone know anything about this, 64 bit drivers?
sb7979 is offline   Reply With Quote
Old 12-24-2008, 09:33 AM   #303
Yeti35's Avatar
I don't believe it is supported. Send RocketRon a PM and see if he can find anything out for you.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 12-24-2008, 10:11 AM   #304
rocketron's Avatar
Trader Rating: 16 (100%+)
The USB Driver company Silicon Labs has informed us that there is no current intention of supporting 64 bit.
So at the moment the Losi interface will not function on a 64bit machine.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 12-24-2008, 10:13 AM   #305
rocketron's Avatar
For those running the 10th Xcelorin ESC there is NEW Setup Software and Firmware available - http://www.losi.com/Support/XcelorinDownloads.aspx
Please download and follow the instructions.
Old 12-24-2008, 04:04 PM   #306
Matt Howard's Avatar
downloaded and installed with no problems, gotta love this support
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 12-24-2008, 09:07 PM   #307
sb7979's Avatar
Well, thanks for the info. That's not the answer I wanted, but at least it's an answer.
For the 1/8th scale speeder, is there a card with more tuning options that will be released? Like the one shown in the photos in the instruction manual? Or will I have to downgrade my PC to a 32 bit OS to be able to program my ESC?
Thanks.
Old 12-24-2008, 10:03 PM   #308
Yeti35's Avatar
Thanks for the info Ron. Downloaded and installed, but no time to test it out.
22 3.0SR
Old 12-26-2008, 04:11 PM   #309
Trader Rating: 15 (100%+)
I'm probably picking up a losi sensored esc tonight for my TC, with a novak 17.5. Anyone have some baseline settings to start with for a medium traction tight carpet setup? I'm running about a 4.40 FDR. TIA guys.
Jonathan Bell is offline   Reply With Quote
Old 01-01-2009, 03:25 PM   #310
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
I installed the new Xcelorin software on my laptop (Windows XP). Once I reboot the system and plug in the USB cable and then connect the adapter the light remains red on the adapter. What am I doing wrong here? I turned off my virus software and have full admin access in XP. The device has a yellow question mark in the device manager in XP. Any ideas on how I can get the adapter light to go to green?
Ty is offline   Reply With Quote
Old 01-01-2009, 03:51 PM   #311
Ty
Ty's Avatar
got it to work. thanks.
Old 01-01-2009, 11:01 PM   #312
Default 13.5
Is it typical to get smoked by Orion 13.5s on the straight. I have a Losi exceleron 13.5 and it seems to be lacking. Do any other people have a problem with it? Could it be a weak magnet?
raj1 is offline   Reply With Quote
Old 01-01-2009, 11:35 PM   #313
rocketron's Avatar
13.5T spec motors that are ROAR approved (which both are) should be close in performance. Differences could be - in no special order - rotor magnet, gearing, drvie train drag, weight, battery nimh or lipo and if lipo what lipo.
If you feel there is an issue with the motor please contact Horizon Customer Support and they will take care of you.
Old 01-02-2009, 12:48 AM   #314
NOFX's Avatar
Trader Rating: 24 (100%+)
Exactly
But with reference to the motors performance, the losi 13.5 is as good as anything out there, i'd assume u have the gearing right, and how are ur motor temps, if its coming off cool, maybe not geared up enough, if its hot, then all the probs rocketron pointed out are where to look, drive train drag is one i normally look at first
2018 Castle Hill Vintage Enduro (Return of the Dukes) - 8th of April, 2018
2018 Castle Hill Vintage Festival Date - TBA
www.hillsoffroadrc.com
Bathurst Vintage Enduro - 17th March, 2018 - 1st round of the NSW Vintage enduro Championship
NOFX is offline   Reply With Quote
Old 01-02-2009, 07:18 AM   #315
default settings are mild to the point of stupidity, crack up the timing a touch and acceleration
I run the losi 13.5 and it runs with and ahead of the novaks,trinity,speed passions... I dont feel the motor is lesser then the rest, but the ESC default settings are just too mild, Hook up the USB update the firmware and dial in some power
www.rcottawa.com
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
