Old 09-26-2008, 04:38 PM   #271
mike ivy's Avatar
Trader Rating: 50 (100%+)
Does anyone have any setting's for 1/12th scale they can pm me the motors Im using 17.5 13.5 10.5 need to know where to set timing, etc,etc,etc, on the speedo and other stuff to
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 09-27-2008, 06:39 AM   #272
Default Thanks again
Will order a 13.5 sensored combo this weekend thanks for all the help looks like a good esc and motor combo not to sure what all the settings mean but hope to find out will be running this in a mi3 with a futaba 3gr 2.4g radio and trackpower lipo at indoor meeting on carpet and rubber tyres
Paul
paul1234 is offline   Reply With Quote
Old 10-22-2008, 08:37 PM   #273
Well I talked to one of the Novak guys at the iHobby show this past weekend and he says that Losi most likely had the GTB sent to China to get copied and threw on the Losi label and made a few additions. Now that I am going on my third sensored 1/10 Xcelorin ESC, I think I have to believe him. The first one would not accept my battery settings, the second one had low speed glitch problems until it eventually wouldn't move w/throttle input unless the motor/car was bumped. I had two different motors with the same symptoms. If the third one I get back from Losi fails on me, I am going to get my money back. I've always liked their electric racing truck kits, but when it comes to electronics I think I'll look elsewhere.
tegmaniac is offline   Reply With Quote
Old 10-22-2008, 09:57 PM   #274
Joel Lagace's Avatar
Race #4 with mine and i love it, 13.5 touring. The software makes changes you can feel on the track,,, more then i can say for my on.off swithc gtb
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 10-23-2008, 07:42 AM   #275
Yeti35's Avatar
I have three of them running them with either Novak or Hacker motors and have not experienced any issues with them. I have two of them in sedans and the other one is in my MF2. I had to make adjustments to the one in the truck since settings I was using in my sedans did not translate well to the truck, but other then that they have been flawless.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 10-24-2008, 07:48 PM   #276
I'm trying to figure out which system to get for a xxxt-cr. Looking at the 10.5 or 6.5 combo. Small indoor clay track with about a 85-100' straight. Which one would u guys get? I have a slash with the vxl combo right now and it rips.
mad316 is offline   Reply With Quote
Old 10-24-2008, 08:52 PM   #277
i ran a 5.5 at an indoor track and WOW it was retarded fast, i would pull on every car goind gown the straigt. tires looked like pizza cutters. But it was to much power, i would have done much better running a 10.5
www.rcottawa.com
Old 10-24-2008, 09:12 PM   #278
Matt Howard's Avatar
I ran an 8.5 in my XXXT-CR this summer on a big track and it was PLENTY of motor. A 10.5 for a smaller indoor track is going to be fine.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 10-25-2008, 01:35 PM   #279
Itīs very curious how a ZTWOEM 120A sensored ESC,
http://www.ztwoem.com/en/products_view.asp?id=31
is identical to a Xcelorin ESC,and the best thing,is that the Xcelorin software WORKS(and you can adjust and load the parameters to the ESC) with the ZTW unit.
In the ESC Software window it appears ff.ff.ff version.
But do not try to make a firmware update,I "killed" my ESC...
Losi,Novak,ZTWOEM,anymore???
chicocheco is offline   Reply With Quote
Old 11-10-2008, 07:26 AM   #280
Gain Time's Avatar
Got this system. Even with the ESC programmed to 40% brakes using the card and with my M11 at 150% EPA on the brakes I only have a slight and I mean very slight amount of braking. Pretty much a free roller. I have calibrated the esc a couple of times. I did test then shut off and restart the esc to save the settings. I dont know why but I just cant seem to get any brakes dialed into the unit.
Any suggestions other than switching to another brand?
thanks.
DON'T TAZE' ME BRO!!!!!!
Gain Time is offline   Reply With Quote
Old 11-10-2008, 08:26 AM   #281
jrxs-r's Avatar
If the car is overgeared, it can also result in very mushy or little brakes. Try going at least a couple of teeth down and see if that improves it.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 11-10-2008, 08:44 AM   #282
schreff's Avatar
Send a message via AIM to schreff
thanks.
This is quite surprising honestly. 40% braking is a LOT on this speedo.
What class are you running? Battery/Motor/Gearing info would help too.
I know on my 12th scale, with 80/53 gearing on a 17.5 even WITHOUT the big power cap, the car still has plenty of brakes. Not that I need them in 12th anyway. In TC, the car will pretty much strip a spur if I have the brake % up too high.
Is the red light coming on when you hit the brakes?
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 11-10-2008, 12:25 PM   #283
Gain Time's Avatar
I have it installed in a RC10R5 and the gearing is tall. 36p/88sp. The gearing may be the issue. Yes the red light comes on.
Old 11-12-2008, 03:07 PM   #284
Gain Time's Avatar
I am going to try to hook up to my computer and see if I can get an update or something. A guy I know uses this same combo with the same gearing and is not having this issue. I will post up if this works for the next unlucky soul who encounters this issue.
thanks.
Old 11-14-2008, 06:09 PM   #285
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i just picked up a brushless system
is there anything i should do be for i run it?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
