Old 09-15-2008, 02:28 PM   #256
Yeti35's Avatar
Originally Posted by dr_hfuhuhurr View Post
So the software won't run on Vista 64?
I don't think so.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 09-15-2008, 02:32 PM   #257
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Just tried it. No Vista 64 drivers. This product will not work with Vista 64. Anyone from Losi know if it will be compatible anytime soon?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 09-21-2008, 06:12 AM   #258
Default How good is this esc im looking
for my first brushless esc and looking at the losi xcelorin 13.5 combo system
How well does it run and compare to others escs all help is welcome
thanks
Paul
paul1234 is offline   Reply With Quote
Old 09-21-2008, 06:19 AM   #259
NOFX's Avatar
Trader Rating: 24 (100%+)
having raced the 13.5 at a couple of big off road meetings, i can honestly say they are as good as anything out there and the 17.5 motor is awesome also for those looking to run in that class
2018 Castle Hill Vintage Enduro (Return of the Dukes) - 8th of April, 2018
2018 Castle Hill Vintage Festival Date - TBA
www.hillsoffroadrc.com
Bathurst Vintage Enduro - 17th March, 2018 - 1st round of the NSW Vintage enduro Championship
NOFX is offline   Reply With Quote
Old 09-21-2008, 06:50 AM   #260
Default thanks nofx did you also use
the losi xcelorin sensored esc with the motor as i would like to get the set that comes with esc and motor
thanks
Paul
Old 09-21-2008, 08:17 AM   #261
Yeti35's Avatar
thanks
Paul
I would say since he has the speedo listed in his sig he has the whole system.
22 3.0SR
Old 09-22-2008, 03:18 PM   #262
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
Default Timing Advance
Does anyone know if the Losi speedo has the timing advance logic in it like the LRP, and supposedly like the latest Novaks ?
jrp is offline   Reply With Quote
Old 09-22-2008, 03:42 PM   #263
Yeti35's Avatar
You can mess with timing either via the software or the quick change card that comes with it.
22 3.0SR
Old 09-23-2008, 08:28 PM   #264
Trader Rating: 35 (100%+)
Default hacker
just wondering if a losi guy can confirm or deny that hacker and losi motors are the same? i have the 17.5 losi and i compared it to a hacker, and they seem identical. either way both great motors. Just wondering if something may be different between the two
nazman01 is offline   Reply With Quote
Old 09-23-2008, 08:34 PM   #265
Verndog's Avatar
Trader Rating: 16 (100%+)
Its pretty much been proven they are virtually identical with the exception of cosmetics. Seeing is believing.
http://www.rctech.net/forum/electric...ml#post4447344
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 09-25-2008, 09:32 PM   #266
NOFX's Avatar
thanks
Paul
Hi Paul, sorry for the delayed reply, i do use the Losi xcelorin esc with the Losi 17.5 and the losi 13.5 and losi 10.5 motors, whether its true or not, in my mind i feel better running a motor that was designed to run with the speed control, especially since the esc has the adjustable timing built in,
To everyone using the system, how good is that programming card, just put the connector pins on the setting u want, plug it in and seconds later, the whole esc programming has changed, of course, for more indepth stuff, the usb programming is also very useful, but to change drag brake % or overall braking its so handy, and much quicker than trying to change my driving style
Old 09-25-2008, 09:45 PM   #267
jrp
jrp's Avatar
I know you can change the timing via programming, but I am curious if it has the automatic timing advance like the LRP Sphere. On the Sphere, the speedo changes the timing as you are driving. For example, it increases the timing when you are running down the straight. Not sure what that is called officially though.
I do know that it makes a huge difference in top speed compared to a speedo that doesn't have it. I know the Novak drivers has this feature now as well. Not sure if it is in the production speedos yet.
Old 09-26-2008, 04:59 AM   #268
Joel Lagace's Avatar
I program mine via USB but at the track this week i wanted to just make 2 changes and was going to use the card but was not sure if we would fudge up the stuff i had set on the pc. Does the card have to have all its pins in the same as u had set on the pc to preserve those settings or if all u want are 2 changes just use 2 jumper pins??
Anyway my friend had his lap top so i made my changes that way, he tried using his card and then hooked up the pc to confirm his other settings had not changed, He said they all changed and where all over the place.....
Guess ill have to read the manual a bit more
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-26-2008, 10:19 AM   #269
rocketron's Avatar
The Card must have a jumper on each setting and only the settings on the card will be changed.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 09-26-2008, 02:24 PM   #270
Ah ha! Great news then. So use all the jumpers and everything else PC set will stay as is.
www.rcottawa.com
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
