Old 08-11-2008, 08:53 AM   #226
schreff's Avatar
Send a message via AIM to schreff
Originally Posted by Ramyuras View Post
Ok, what is the purpose for the new fireware? and if any one knows where can I get the steel tray.
Thank you
The latest firmware was created to help issues with Futaba 2.4 systems. The speedo wouldn't turn on and initialize properly because the Futaba 2.4 seeks for a channel differently than that of other 2.4 systems. Because of that, you'd have to turn the car off and on a couple times before the speedo would actually be ready for use. The firmware does not enhance the speed control or make it faster. It was merely to fix functionality issues.
As for the Steel tray, the next batch from Losi isn't due for a little while now. Just check around at some online shops and other hobby shops as someone is bound to have one.
-Jason Schreffler-
TLR|Horizon Hobby|Spektrum|AKA|Team CRC|CR Graphics|TQ Wire|Radio Impound Podcast
schreff is offline   Reply With Quote
Old 08-11-2008, 01:50 PM   #227
Thank you.
Ramyuras is offline   Reply With Quote
Old 08-18-2008, 10:40 PM   #228
SteveJa's Avatar
Trader Rating: 17 (100%+)
I think I have a problem with my ESC.... with the car and radio on if I turn the wheels left and right a few times quickly the motor/car lurches foward ??
I have a JR Z1 with synthesized receiver.
Anyone else have problems with this or like this ?
thanks
SteveJa is offline   Reply With Quote
Old 08-18-2008, 10:43 PM   #229
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
thanks
Kinda, when i turn the radio off before my car (i have DSM) the car will apply about 5% throttle. I usually do this because running the radio with old NICDs can sometimes cut your race short.
This didn't happen with my old system.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 08-18-2008, 10:47 PM   #230
SteveJa's Avatar
yours sounds like the failsafe. i am having alot more and different problems.
Old 08-18-2008, 11:34 PM   #231
SteveJa's Avatar
well my problems are with the JR ZR1 synthesized. when I use a spektrum receiver / moduel I have no problems. put the synthesized in.... all the problems come back..... thanks losi... now I have to get a new receiver.
Old 08-19-2008, 07:15 AM   #232
Yeti35's Avatar
Not sure why it would be Losi's fault that you have a bad receiver.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-19-2008, 04:15 PM   #233
SteveJa's Avatar
The receiver is not bad.... the receiver works fine..... but when the receiver is used with the losi esc it does not work correctly. you can say what you want and think what you want but I know for a fact that the esc and jr z1 synthesized do not work correctly together.
losi esc and jr z1 with synthesized does not work !!!!!!!!!!!!!!!!!!!!!
Old 08-19-2008, 07:06 PM   #234
StewartFan20's Avatar
Default Help
What does it mean when all the lights blink after you turn it on?
I have updated to the latest firmware version and reset to factory defaults. When I set it up, I hold down the button on the switch and when the amber light comes on I release the button. Then I pull full throttle and the green light starts blinking. I hold full throttle until the light goes solid. I then give it full brake. The red light starts blinking. I hold full brake until the red light goes solid. I then return the trigger to neutral. The blue light starts blinking. I wait till the blue light goes solid, then I turn the switch off. When I turn the car back on, all the lights start blinking and I don't have any throttle. I have steering, but no throttle.
It worked for a while, then I bumped a board with the nose of the car and lost throttle. A marshal turned the car off and back on and I got some throttle, but it would cut out.
Any ideas?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 08-19-2008, 10:35 PM   #235
rocketron's Avatar
Trader Rating: 16 (100%+)
Any ideas?
All the LEDs flash means the sensor wire is not fully connected or faulty
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 08-20-2008, 05:57 AM   #236
Thank you.
Old 08-21-2008, 05:16 PM   #237
What's the lowest you can set the LVC on the Xcelorin? Looking for a speedo to run in 1/12th this fall, using a SMC 1S lipo and a 13.5 for stock class. Already planning on using a 2S lipo receiver pack for the receiver and servo. But need the ESC to be able to set the LVC to 3V.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 08-21-2008, 06:48 PM   #238
rocketron's Avatar
If you set the LVC to NiMH you can adjust the cutoff voltage down to 3.0V
going up by 0.1 increments
Old 08-21-2008, 06:51 PM   #239
Sweet!
Old 08-26-2008, 12:31 PM   #240
radio_car_racer's Avatar
Xcelorin 10.5 SPEC Motor
do Losi have a spec 10.5 available?
radio_car_racer is offline   Reply With Quote
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
