Old 07-09-2008, 01:29 AM   #196
NOFX's Avatar
Trader Rating: 24 (100%+)
yeah we were looking at this a month or so ago, we decided the figures quoted are wrong, either by losi or everyone else out there because my 13.5 goes as hard as any other motor out there
2018 Castle Hill Vintage Enduro (Return of the Dukes) - 8th of April, 2018
2018 Castle Hill Vintage Festival Date - TBA
www.hillsoffroadrc.com
Bathurst Vintage Enduro - 17th March, 2018 - 1st round of the NSW Vintage enduro Championship
NOFX is offline   Reply With Quote
Old 07-09-2008, 10:08 AM   #197
so how do you calculate the theoretical top speed and roll out when the rpm info is so off? do you just select the FDR independent of the speed and roll out?
shadowless is offline   Reply With Quote
Old 07-09-2008, 05:13 PM   #198
mike ivy's Avatar
Trader Rating: 50 (100%+)
Hey rocketron question, Do you know the part number to the 4-cell heat sink replacement cover and how do you like it so far for 1/12th scale?
Originally Posted by rocketron View Post
Your right the instructions do not mention 4Cell but I have used the sensored esc in 12th scale for a season of 10.5T racing without a problem. In mod you may need to run a power cap, or seperate battery - not certain.
i am using the optional 4cell heatsink replacement cover too
[-eXpress motorsports-] [-TQ Wire-]
1/12th Fo' Life!!! R.I.P Mike Reedy, R.I.P John Williams
[-Horsham RC-] [-Jackson RC-] [-RC Car World-] [ Black Out Free 2015 ]
mike ivy is offline   Reply With Quote
Old 07-09-2008, 05:19 PM   #199
Matt Howard's Avatar
http://www.losi.com/Products/Default...rodID=LOSB9352
Here ya go Mike.
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 07-09-2008, 05:20 PM   #200
mike ivy's Avatar
Thanks Matt much appreciated
Old 07-09-2008, 05:20 PM   #201
rocketron's Avatar
Trader Rating: 16 (100%+)
Here it is: http://www.horizonhobby.com/Products...rodID=LOSB9352
I've run it using both the 10.5T and 13.5T locally without any issues at all. We have some pretty quick guys here in SOCAL and never felt i was down on power or punch.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 07-09-2008, 05:22 PM   #202
mike ivy's Avatar
Thanks rocketron
Old 08-07-2008, 09:57 PM   #203
Joel Lagace's Avatar
ITs friday nite and the horrizon crew is in bed so ill see if there is any help here..
Got my new system and having issues getting the USB adaptor to turn green and be scene in the setup software.,
VISTA System
-AVG turned off
-installed included software
-plugged in usb adaptor
-vista attempts to find but cannot find drivers
-went online dl the newest software repeat above steps,reboot as promted
-nothing works. Software does load though.
-tried device manager and manually point the adaptor to the driver folder in the losi folder...message reads "found driver yadayada... ACESS IS DENIED
-If i Try anything with AVG turned on and it comes up with 2 virus warnings: Fujacks from file name driver\slabunin2k.exe right after it fails to load the found driver
Short story softwar installed.... USB Adaptor turns red but wont take drivers
Ideas? Is Losi including a free virus in every box? LOL
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-07-2008, 10:02 PM   #204
ps i have full admin previlages
www.rcottawa.com
Old 08-07-2008, 10:44 PM   #205
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
joel schreff had this problem before he wound up removing avg then installing the losi software an then reloaded the avg all is well now is it a 64 bit OS cause it wont work on 64 bit or at least it wouldnt for me i had to put a 32 bit os to get it to work
DENNIS STORTI is offline   Reply With Quote
Old 08-07-2008, 10:51 PM   #206
Yeti35's Avatar
Are you sure the USB port is functional that you are plugged in to? If you are still having issues I have a Vista box here I could try to install it on and see if I get the same issue. I mainly run XP though but I could test it out for you.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 08-07-2008, 10:56 PM   #207
Yeti35's Avatar
So it is just an AVG thing, not a driver issue under Vista? I did notice something in that the download section of the Losi site does not work. I though it was an issue on my end, but asked a friend to try it and he had no luck either. So Ron, someone there may want to look into that.
22 3.0SR
Old 08-07-2008, 10:57 PM   #208
rocketron's Avatar
Joel
with Vista you need to log on as the ACTUAL admin account even IF you have those privlidges. You can also run the INSTALL program as the actual admin while your logged in as yourself.
keep AVG turned OFF. There are no virus on the drivers
the software on the cd is the same as can be downloaded
do not use ANY firmware on the CD get that from the web support site
any other issue please post back ok?
Old 08-08-2008, 06:07 AM   #209
UPDATE:
VISTA HOME PREMIUM
-enable admin account! WHAT A CLUST F!#$
-click start type command prompt in search
-right click command promt icon "open as admin"
-WTF so stupid
-in command prompt type "net user administrator /active:yes"
-log off now you have admin account.. Man o man so stupid
Attempt 1
-disable avg
-reinstall
-usb red
-manually install driver
-usb red
-no luck
ATTEMPT 2
-uninstall AVG (thanks dennis s)
-reinstall program
-propted by vista about 2 drivers that it dont like, say yes anyway
-softwar installed
-plug in usb go and point the thing to its drivers
-turns grean!
-load software green usb,plug into ESC green light for esc
-success
-re-install avg
-test again
-all ok
-log out of admin
-log into my usernam admin account
-all operations ok
-SUCCESS
Thank you AVG and VISTA for making life so easy....
www.rcottawa.com
Old 08-08-2008, 06:20 AM   #210
LOL oh boy not my day!!!
Trying to download the new firmware. Neither Opera or IE will let me "save as"
Can somone post the lastest file here? its like 36kb
www.rcottawa.com
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
