Old 06-10-2008, 04:26 AM   #151
Matt Howard's Avatar
Originally Posted by JJC View Post
Anyone tried the Losi Xcelorin 10.5? If so how does it compare with the Novak, LRP, Orion, Nosram etc 10.5's?
The Losi ESC and Motor combo can be had for a lot less than other sensored brushless ESC's - almost seems too good to be true....
I ran the 10.5 a couple weeks ago at the Delta Fireball Classic here in Lincoln NE. It was just as fast as anything else on the track and it didn't thermal like most others did while trying to keep up with me. So yes, it's fast
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 06-10-2008, 04:37 AM   #152
NOFX's Avatar
Trader Rating: 24 (100%+)
they are excellent value, i have a 10.5 and 13.5, i havnt run the 10.5 yet, but the 13.5 is easily on par with any of the other brands, i'll be running the 10.5 this weekend..
Matt, can you tell me what timing you had it set at on ur 10.5?
2018 Castle Hill Vintage Enduro (Return of the Dukes) - 8th of April, 2018
2018 Castle Hill Vintage Festival Date - TBA
www.hillsoffroadrc.com
Bathurst Vintage Enduro - 17th March, 2018 - 1st round of the NSW Vintage enduro Championship
NOFX is offline   Reply With Quote
Old 06-10-2008, 10:18 AM   #153
rocketron's Avatar
Trader Rating: 16 (100%+)
obviously i am not Matt, but my reccomendation is to run as little timing as you can and gear for speed, timing tends to generate heat. then use timing as a fine tuning adjustment IF needed.
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 06-10-2008, 05:36 PM   #154
NOFX's Avatar
thanks mate, thats what i've been hearing, i ran the 13.5 with the standard 6 deg timing, geared conservatively and it was still very quick and temped at 110 after the race, i know where i should be gearing the car, i'll drop the timing maybe to 2 deg and check temps and go from there
Old 06-11-2008, 02:56 PM   #155
JevUK's Avatar
Looks like my friends problem with his excelorin was the LVC. It's seems it's overly sensitive. Even on 6v it was cutting in, he's since turned it off/nimh mode and no problems. I think esc needs to wait a fraction of a second longer before engaging the lvc.
MRT, Novak, Spektrum, Sanwa, Tamiya, Alleven RC, Maxamps, CheapBatteryPacks, Duratrax Ice, Pro Peak PSU, Nuova Faor, McLarney Racing, Futaba, KO Propo, Team Associated, Enerland.
JevUK is offline   Reply With Quote
Old 06-12-2008, 10:33 PM   #156
wpr2's Avatar
Matt, to bad about the rainout last week would have liked to have been racing. I know it's nitro this week and I'm not going to be racing but I would like to come up and have you checkout my system if that would be alright.
Thanks Alex
WolfePak Racing
wpr2 is offline   Reply With Quote
Old 06-13-2008, 04:50 AM   #157
Thanks Alex
That's fine, bring it on over whenever you get there.
RCTech #361
Old 06-15-2008, 09:19 PM   #158
Questions?? Ok to shorten motor wires?
My new Xcelorin 10.5 is in and it runs great! Just one question...as this is my 1st brushless system I wanted to make sure it was ok to shorten the motor wires? I ordered a shorter sensor wire, so that is taken care of. Just need to know about the 3 motor wires.
Thanks.
NU_Blackshirts is offline   Reply With Quote
Old 06-15-2008, 09:38 PM   #159
scrawl's Avatar
Is the Xcelorin happy to run fanless with a 13.5?
scrawl is offline   Reply With Quote
Old 06-15-2008, 10:30 PM   #160
Yeti35's Avatar
I finally got to run my Xcelorin speedo this weekend and have to say it is very nice. I ran it with a Novak 13.5 and felt it was pretty smooth. I am impressed enough to get another one, once the funds permit me to do so.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)And racing one of them again!!
22 3.0SR
22T 2.0 w/ Exotech chassis
Yeti35 is offline   Reply With Quote
Old 06-15-2008, 10:33 PM   #161
Yeti35's Avatar
Thanks.
Yes, you can shorten them as long as you don't make them too short that you don't have enough length. You are not hurting anything by doing so.
22 3.0SR
Old 06-15-2008, 11:43 PM   #162
rocketron's Avatar
if your running TC it may get hot depending on the air temp. In a buggy you should be fine though.
Old 06-16-2008, 07:57 AM   #163
Thumbs up
Thanks for the info, Yeti. Looks like I will be doing some wire shortening tonight.
Old 06-16-2008, 11:40 AM   #164
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Best quote of the offroad season yet-"Get out of the way! you're not even a contender!"- author to remain nameless
That sounds like a famous quote I heard a long time ago:
Drive-thru!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 06-18-2008, 08:57 PM   #165
Need help with my xcelorin I ran it a few times and it works fine but this weekend I had a problem with the motor stopping and not moving it sound like when the pinion and spur got out of mesh but that wasn't the case the pinion and spur was just fine did anyone have that problem? if so what did you do to fix the problem.
Ramyuras is offline   Reply With Quote
LOSI Xcelorin Brushless/ESC combo ORANGE DOG R/C Items: For Sale/Trade 26 09-01-2008 10:44 PM
<< ** New Losi Desert Truck with NIP Xcelorin Brushless Combo ** >> RcOneNitro R/C Items: For Sale/Trade 28 08-09-2008 07:35 PM
XCELORIN brushless? matthewh Micro and Mini Scales 48 06-26-2008 04:34 PM
losi xcelorin brushless system HarleyMf2 Electric Off-Road 3 04-27-2008 09:39 AM
Losi Xcelorin S Brushless Electronic Speed Control SoCalMitch Electric On-Road 12 03-27-2008 08:08 PM
