Formula 1 Electric who makes em ?? >
Old 09-23-2008, 03:33 AM
  #361
Marty Peterson's Avatar
Originally Posted by Foxxrocket View Post
Sorry to interrupt you guys, but I was wondering where you can get those ferrari decals.
Thanks in advance.
I have a master set, I am in the middle of a move here and I guess in about 2 to 3 weeks I can see if our decal guy can make a few sets.
So if you email here [email protected]
Marty Peterson is offline
Old 09-23-2008, 03:39 AM
  #362
Originally Posted by Mark Flores View Post
Hi. Will those foam tires fit a regular 103RM? Its got the same front end, I noticed. What about the rears?
back in the Thread we did cover this,
Ok The F103 Running on Pan car Foams front and rear.
we went over the fronts they fit and work great.
http://www.rctech.net/forum/electric...akes-em-6.html
as for the rear Thanks to MXRick and Aphl, Yes you can drill out the Tamiya F103 Rear Bearing holders. to the size of a normal flanged rear axle bearing for Pan Cars. and with the holes drilled out from the back side of the holder and installed on the F103 not only works good but looks great.
I have not tested them yet but I did run around out front and they work better than the Tamiya foams ~ But the rear is about 6mm wider now and the fronts are the same I did make a set of aluminum spacers to put behind the front wheel, to help shim it out so it works and fits right and looks good.
Old 09-23-2008, 08:28 AM
  #363
Foxxrocket's Avatar
Ok, so I should check back with you in 2 to 3 weeks, when you get things in order?
Foxxrocket is offline
Old 09-23-2008, 08:39 AM
  #364
K_Spec_RC's Avatar
I'm not Marty, but I'm pretty sure that the V103 has a pan car style rear axle that allows it to use 1/10th pan car tires.
As far as race pics, yes I took some and they will be up soon.
K_Spec_RC is offline
Old 09-23-2008, 09:49 AM
  #365
Yes The V103 is a Pan car rear axle setup not Tamiya.
Old 09-23-2008, 10:30 AM
  #366
Ok go here http://picasaweb.google.com/mlpmotor...F103RMUpgrade# ok I was working on this for my son I took it back out of the box and took a few pics. I am running GRP front tires with the F103 front bearings in them and spacers to keep the wheel true on the axle.
The Rear I am running GRP Tires and a CRC Genx 10 setup works the best and is centered with the Tamiya F103 rear pod it was easy I just drilled out the Tamiya height adjuster to fit the 1/10 scale Pan car axle bearings and installed them back in the pod setup in reverse so the little 1/4 moon shapes are pointing out not in like the F103.
Old 09-23-2008, 10:38 AM
  #367
Plus I would think with todays economy I know it is hard to get the funds up for a new car.
So if you have a F103 or a F103RM you can do this easy just order the CRC rear axle parts and the GRP tires or I would go with Jaco they are easy to get.
Maybe after we finish with the move and get things running at 100% around here I might put together a Kit for your F103 & Rm to run these wheels and tires and also will add it to our MLP MP 3/8 Upgrade kit for the F103 ok.
This will not make your F103 or RM a V103 but it will give you better rear traction and better gearing.
Old 09-23-2008, 11:29 AM
  #368
mxrich's Avatar
Pic should be coming soon.
mxrich is offline
Old 09-26-2008, 02:57 PM
  #369
Could you list the parts needed to convert the rear pod for a CRC rear axle?
And do you know where they have theese parts in stock?
Thank you
bibben is offline
Old 09-26-2008, 11:00 PM
  #370
We are in a move right now and should be done next weekend I hope.
So everything is packed up here is what I could find for you.
1725 - 1/10th Lg Ring Diff Hub - GX10 - RED
SKU: 1725
1733 - 1/10th Left Clamp Hub - Red
SKU: 1733.
4202 - Large D-rings - Lightened
SKU: 4202
1728 - Large D-ring Axle - 10th/SS Fits Genx 10
SKU: 1728
4126 - 8-32 Nylon Locknut (2)
SKU: 4126
4121 - Aerodiff Spacer collar
SKU: 4121
1229 - Diff Balls for gear (100 pcs.)
SKU: 1229
http://www.teamcrc.com/crc/index.php
Old 10-05-2008, 12:10 PM
  #371
ChadRacing's Avatar
What companies make diffusers for F1's? I would like to to get one if they actually work. I thought i saw a carbon fiber one on a pic.
Any help is appreciated
ChadRacing is offline
Old 10-05-2008, 04:05 PM
  #372
snoopyrc's Avatar
http://www.geocities.jp/wrfyt827/RCP021-1.html
http://d-drivesportsenglish.com/inde...products_id=27
snoopyrc is offline
Old 10-13-2008, 04:13 PM
  #373
mxrich's Avatar
Time to stop talking and start racing! We will be hosting some F1 events in Southern Illinois, Chattanooga, TN and Dalton, GA. There is also a chance to bring it to Southern Ohio also. Keep watching here for info. All you guys have to do is the three "ups" show up, signup, and lineup! Are we ready to race?
mxrich is offline
Old 10-14-2008, 05:20 PM
  #374
black-knight's Avatar
Im getting ready to race a Corally F1... at our local track the F1 class is for any F1 kit, 2wd or 4wd, with 27t brushed or 17.5bl
Attached Thumbnails Formula 1 Electric who makes em ??-f1%2520with%2520body%25202.jpg
black-knight is offline
Old 10-14-2008, 06:35 PM
  #375
mxrich's Avatar
Now your cooking! Both of the Corally's, new and old versions are great cars. We run 2wd and 4wd together also with 2wd using 27T or 17.5 and 4wd's with 19T or 13.5. For 2009 we will be doing some longer mains with 540 silver cans in the 2wd's and 27T in the 4wd cars. Should be a lot of fun in between the normal F1 series races. Seems to be catching on in a lot of places now. In the near future we will have a website to purchase several brands of F1 cars to choose from and parts. Keep an eye open here for info. So far it looks like the 2009 F1 builders cup may be in Chattanooga,TN but that could change if a better deal/location pops up. Any of you guys seen the new Tamiya F103 anniversary edition?...very nice car.
mxrich is offline
