Old 09-02-2008, 11:59 PM   #301
K_Spec_RC's Avatar
Send a message via MSN to K_Spec_RC
Any idea on the price of the Viper X10 200mm car? I really want to get the class started locally if there is enough interest. Also, I know you have the Touring car style front end on the one on the site, but will it be offered with the Associated style front end as well? If I read correctly, all WGT legal cars must use that front end?
HighVelocityRacing.com | TurtleTraxRaceway.com | itFitzDesign.wordpress.com | Misfitz Motorsports | Jconcepts | KO Propo | Tekin | Kyosho RB5 SP | Kyosho Ultima SC
K_Spec_RC is offline   Reply With Quote
Old 09-03-2008, 12:13 AM   #302
Marty Peterson's Avatar
R/C Tech Charter Subscriber
K Spec
I will not post prices ok, here anyway but it is the same price as the Viper F1 maybe a few dollars more with the frontend thing.
Well I have not checked the WGT rules as for late I thought it said a front end with a lower locked suspension and spring loaded king pin? But if I am wrong than I will put any front end on it that people want I like the CRC my self.
Here for the fun of it!
Selling HPI F10 Front Knuckles and Complete Rear Axles W/Diffs Ball and Gear.
W/12mm TC Hubs & W/14mm F1 Hubs Good for std bearing Pans cars. STD Bearings!
eBay item number: 200947192161,200947193175,200947187493
Marty Peterson is offline   Reply With Quote
Old 09-03-2008, 06:00 AM   #303
Hey Chad.
I must also add that this car
Has an adjustable wheel base. That is to say the length of the Chassis can be extended.
From 254mm (V103SW) Pictured
or 259mm F103 or V103
or 280mm F201
That is a big plus for this type of chassis. and will help in tuning to the track you are racing on and your driving style.
Old 09-03-2008, 05:27 PM   #304
mxrich's Avatar
I told you he would "splain" it! Dang, now I feel special...I'm all verklempt.
A side by side 4 cell chassis? Now I'm jealous.
4cell F1 is way cool even against the 6 cell cars. At least until you hit the back straight at the Bowl. Then they kind of move out of the way a little. Speaking of... I didn't know the 4wd would go that fast until I hit the back wall. Dang near turned it back into a kit! Some reassembly required.
mxrich is offline   Reply With Quote
Old 09-05-2008, 07:25 PM   #305
Well MX I guess I will get that F1 car back in a shoe box for repair is that what your telling me.
Hey Chad here is the car, should ship Monday - Wen test it if you can and the Viper F1 will be ready I hope at the same time. I do want this car back. I need to cad it up I think this will also go into production, So we now have an entry level car and a Racer (Viper F1) and this Car ! not sure where it is going to fit in but it is sweet!
Later
Old 09-05-2008, 08:19 PM   #306
raffaelli's Avatar
Later
picy no worky
24ITA
raffaelli is offline   Reply With Quote
Old 09-05-2008, 08:25 PM   #307
Yep it is makin me crazy I will fix it
Old 09-05-2008, 09:10 PM   #308
K_Spec_RC's Avatar
great stuff Marty! I was just talking with Chad about this car today, I cant wait to see it!
Old 09-05-2008, 09:59 PM   #309
Thanks.
I can't wait to drive it!!! and for you guy's to see it and test it.
With the adjustability of this front end and wheelbase and the rear pod setup Man it is just sick!
With or with out the shock setup on it or the Cantilever Suspension, with the fixed lower arms and adjustable top links (caster) & (camber) and you still keep the push rods for the car these will adjust chassis tweak in & out of the chassis, I am thinking of doing the lower arms out of carbon fiber with mechined aluminum ends on them. But we will see.
Old 09-06-2008, 09:34 AM   #310
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
2 questions?
for f1 in future, foams or rubber?
2nd, will a f201 body set fit on a 103. thx.
R
UltegraSTI is offline   Reply With Quote
Old 09-06-2008, 09:50 AM   #311
I would say Foams but there are still Rubber slicks out there for your F103 Cars.
Yes you can make a F201 Body fit the F103.
I use the F201 front wing and cut the last mounting hole back so it will fit in the F103 I do not use the top cove or I cut the wing mounts down to let the body drop down.
Old 09-06-2008, 01:43 PM   #312
snoopyrc's Avatar
How much longer is the 201? Do you have to trim the shell to put it on the 103? As long as we are keeping them in the same class I think I will stay with the 201, at least until I can no longer get parts.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 09-06-2008, 04:47 PM   #313
I think the F201 is 280mm and the F103RM is or F103 is 265mm so 15mm the body need to be cut for the front suspension on the F103 and not the F201 I did take some off the nose and I have always cut the rear Different.
I will post a pick ok
Old 09-06-2008, 05:20 PM   #314
mxrich's Avatar
I thnk you are covered on parts until 2047 at least!
Old 09-06-2008, 05:33 PM   #315
You cut the rear of the body out first and the rear mounting holes then install body and mark out the front suspension. and your done.
WTB Electric Formula 1 Car IL_AudiRacer R/C Items: Wanted to Buy 2 05-03-2008 04:56 PM
Electric Conversion REVO, who makes the best conversion? rclab1 Monster Trucks 3 11-25-2007 12:27 PM
looking for 1/10 electric formula 1 pepecueva Electric On-Road 12 08-02-2007 09:15 AM
1/5th Formula 1 FG Bigfoot Oval, Larger Scales and More 0 10-03-2006 07:35 AM
Who makes the best shocks for electric touring Yokomo Aust Electric On-Road 40 06-25-2004 07:11 PM
