Old 07-28-2003, 10:39 AM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default TRF414MII one-way glitch
just the other day i through my one-way into the car and when it goes down this not very easy turn i drop the gas and floor it and it glitch's
i was driving a diff the other times and i know its not a electronic thing
could it be that i need to turn down the brakes a little
should i lighten the back diff a little
Calvin Ng is offline   Reply With Quote
Old 07-28-2003, 11:42 PM   #2
SpeedTech's Avatar
Calvin,
I had some problem with the center one-way on the 414M2. Because the layshaft have flat spots for setscrew (for when you're using 4WD pulleys) the edges of the flat spots tend to catch the pins inside the one-way bearing. Check if the pins inside the one-way are worn down and out of alignment inside. When it is out of alignment, the one-way will be there sometimes and sometimes it will lock like a 4WD pulley, making the car feel like it is glitching. There is really no fix that I know of for this, but an option you have would be to replace the center layshaft with a silver one from the 414x (call Tamiya on this) and it is of a harder material and it is less likely to have the edges on the flat spot deform and catching the one-way pins (I'm using the 414x shaft on my car at the moment)
If you're referring to the front one-way, then I'm not sure what can be causing it.
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 07-29-2003, 08:57 AM   #3
Registered User
Calvin Ng's Avatar
thanx a bunch i'll go check that out tongiht
Old 07-29-2003, 09:03 AM   #4
Disney's Avatar
Originally posted by SpeedTech
Calvin,
Steve Wang
Disney is offline   Reply With Quote
Old 07-29-2003, 10:36 AM   #5
Registered User
Calvin Ng's Avatar
any other way to fix it besides getting a new one?
Old 08-05-2003, 10:06 AM   #6
Registered User
Calvin Ng's Avatar
Calvin,
Steve Wang
im still very new to r/c and i dunno what the pins are and stuff but i can open it
can you explain to me how i can fix it and what are the pins and stuff.
or even better can you show me a pic
thanx
[FS]: Tamiya TRF414mII for $80 MUST GO! oldskoofame R/C Items: For Sale/Trade 18 07-14-2005 11:47 PM
For sale: TRF414MII+everything oldskoofame R/C Items: For Sale/Trade 0 06-04-2005 11:30 PM
TRF414mII Vs XXX-S Graphite Plus Calvin Ng Electric On-Road 9 05-18-2003 08:28 PM
Will This Fit On The TRF414mII Calvin Ng Electric On-Road 5 05-16-2003 09:13 PM
Surikarn's TRF414mII Calvin Ng Electric On-Road 0 05-10-2003 11:45 AM
