Old 07-27-2003, 11:31 AM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Battery Recovery (Help)
can someone tell me step by step how to recover batteries
sanyo 3300's turned into 3000's
my 2400's turned into 1800's
example: do you charge it first and then zap it or do your discharge it and tray it then zap
Calvin Ng is offline   Reply With Quote
Old 07-27-2003, 01:02 PM   #2
Cole Trickle's Avatar
I've heard both good and bad about about zapping, but as far as I understand, zapping basically can prolong battery life a little, but when it's time to use it, there aint much back anyway.
However, I dont know if that's the case with your packs.
What I do know for sure, is that discharging down to 0,9 volt pr. cell - preferable with an active equalizer - will help a lot. Afterwards, give them a complete charge.
A tray usually takes the cells all the way down to zero volt. This increases the output voltage, when the pack is in charged state. But it's also known for decreasing capasity. Since you're using a tray, this is probably a part of your problem. Taking cells down to zero volts usually introduce some false peaks, which might be your main problem.
Another issue might be your power supply or charger, which can cause false peaks.
Another source to the problem: Storing.
Please tell how the packs perform on the track, mainly about punch, but also about runtime. Also, is your packs sligthly warm after a complete charge? This can help diagnosticing the problem.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-27-2003, 05:11 PM   #3
Registered User
Calvin Ng's Avatar
the sanyo's have not as much punch as the gp's but that is pretty much normal
i dont have a tray myself i might borrow my cousin's to fix these batteries
im using a millenium pro and im setting it to nimh 2 which doesnt overcharge it. once it hits the peak it stops.
charging them at 5 amps
the batteries come out warm like normal it seems its a bit hotter then it was when i frist got it. but when first got it i was running indoors in the winter. now im running outdoors in around 27 degress celcius weather. thats why its a bit hotter
so what should i do? thanx!
Old 07-27-2003, 11:47 PM   #4
ruftnik's Avatar
Send a message via Yahoo to ruftnik
Default Re: Battery Recovery (Help)
how did you know that your 3300mah battery had turned into 3000mah and 2400 into 1800???
ruftnik is offline   Reply With Quote
Old 07-28-2003, 07:00 AM   #5
I recommend you get a equalizer with auto-cut off. Integy and Robitronic got some nice ones.
lipo recovery BSS07 Electric Off-Road 32 07-24-2008 06:32 PM
Hakko 936, Spintec battery manager, Ko Ex-10, Spektrum Pro, tekin battery doctor Breeze R/C Items: For Sale/Trade 2 12-08-2007 09:47 PM
33 Promatch 3300 NIMH battery cells and Battery Case nitro468 R/C Items: For Sale/Trade 10 08-06-2007 05:21 PM
FS: New Lipo battery 8000mah 7.4v fits in most battery trays aussiebuddha Australia For Sale/Trade 0 11-22-2006 03:23 PM
10 6 cell battery packs, 3 stock motors and 2 sakio battery cases $52.00 ??? bigoTC3fan R/C Items: For Sale/Trade 1 09-22-2004 06:07 PM
