Old 04-26-2008, 09:18 AM   #1
racing_jason's Avatar
Questions?? Novak GTX Set Up
Hey i just have a question on the setup on the GTX. It says you can adjust the Minimum Drive Percentage, exactly what is that? Is it sort of like the push control on the Tekin FX Pro?
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 04-26-2008, 09:51 AM   #2
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Minimum drive is the amount of throttle % you apply before the ESC will start to produce power. Its good for stock racing where you need a lot of momentum, for modified not so much.
Think of it as sensitivity, the higher the % the more sensative your throttle will be.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 04-26-2008, 02:26 PM   #3
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Yup. It would be easier to just run a lower number profile. 3 is the factory stock setting. I usually run 2 in stock, since it does give you a punchier feel for the car. Then just a little higher number for 19t or mod. Makes it easier to control the car when throttle is smoother.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-27-2008, 03:53 PM   #4
ok so the lower the number the more sensitive and the higher the number the less sensitive right
Old 04-27-2008, 03:55 PM   #5
Correct
ProMatchRacing
Team Corally
Superior Hobbies
Old 04-27-2008, 03:57 PM   #6
awesome thanks for all the quick replies
Old 04-27-2008, 03:58 PM   #7
No problem. Good luck
ProMatchRacing
Team Corally
Superior Hobbies
J Concepts BJ4WE CHEAP!!! NIP NOVAK 10.5 & Novak 4300 w/Sintered Rotor Zac R R/C Items: For Sale/Trade 15 02-13-2008 06:13 PM
LRP Sphere tc, Novak 13.5pro, Novak 10.5 pro, Novak 13mm rotor theisgroup R/C Items: For Sale/Trade 9 01-08-2008 11:21 AM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
For Sale Novak 3.5 brushless motor with Novak Heat sink $60.00 SHIPPED!!! Marcos.J R/C Items: For Sale/Trade 14 06-24-2007 08:29 PM
Rivergate RCD30, Novak Millenium Pros, XXX4G+, XXXTMF, lehner/novak BL Jman-x R/C Items: For Sale/Trade 1 09-14-2005 10:51 PM
