TRF414M, 404x, 414, 414X >
Like Tree18Likes
Old 11-14-2002, 07:48 AM
  #1531
Aurra Sing's Avatar
Originally posted by imataquito
hm ...... for more stearing reduce the front upper arm spacers on bulkhead??
i am running this setup now.... need more stearing on and off power and more coner speed while turning- less scrubbing of the wheel
heres my current setup and any ideas is welcomed
Front roll centre
FF:0.7 FR 0
RF:3 RR 2
running abt neg 1.5 front camber and rear neg 1
spacer for camber link on bulkhead:
front 0mm
rear 0mm
shortest wheelbase and dual one ways
Yes, making the front upper link lower than the rear will give you much more agressive turn-in and steering, but it may be harder to drive. I suggest next time you try adding a 2 or 3mm spacer to the rear upper link. Are you still running the C1/C2 switched?
Aurra Sing is offline
Old 11-14-2002, 07:51 AM
  #1532
Aurra Sing's Avatar
Originally posted by Vic
Aurra,
Thanks for the help!
I am running on carpet these days.
Can you help me what is this, I do not understand it.
Upper links were - F:1mm R: 5mm
One more question if you do not mind--I am using +0.5 toe-out in front Should I use -0.5 toe-in tom be more stable coming out of corners with speed?
Thanx
I refer "Upper links were - F:1mm R: 5mm" as the spacing that the upper camber links on the bulkhead side of the car. The kit setup was 2mm on all four corners.
What was the problem again? You have too much on-power steering?
Old 11-14-2002, 08:38 AM
  #1533
imataquito's Avatar
i am not sure... i guess it the switched one as i go get more aggerasive and more stearing everywhere with this one compared to the one if i switch it from this setup......
ok...... will try putting spacers on the rear....
ahh i forgot abt the formula....... forgot to give u the varibles...
sorry.....
X= the lenght in relation from the centre of chasis......
Y= lenght from the ground level........
A- the pivot point for the camber link on c hub
B- """"""""""""""""""""""" camber link on the bulkhead or suspension mount
C- pivot point of the c hub on the a arm
D- """""""""""""""""" A arm on the chasis
so Xa is the distance of the A varible from the centre of chasis
and Ya is distance from ground for A varible...
imataquito is offline
Old 11-14-2002, 10:22 AM
  #1534
reflekt's Avatar
reflekt: i think u have more then just 1 problem on the outdrives touching the wheels ....
the spacers u used mite not be suitable for raising the A arm holders.......
try loosening ALL the bulkhead screws ONLY .. i am pretty sure ur chasis will bend very badly .... because the shims u used is too big ...
try cutting of shaving it on one side- the side which will face the bulkhead.....
and insteed of using the 3-4mm front and 4-6mm in the rear u can try 2-3mm front and 4-5mm rear ........
actually, the shims i used are perfect size. they are each 1mm. and the diameter of each spacer is equal if not smaller than the diameter of the 2mm spacers provided with the kit. also, at my track, there are many trf414/m/m2 racers and if u think my spacers are too thick, think again. i've seen huge one piece spacers underneath the blocks that others use. also, i've reduced my amount of spacers to..
FF:0.7
FR:2
RF:3
RR:2
i'm gonna try the car today at the track and see how it runs. thanx for all the help. peaches
reflekt is offline
Old 11-14-2002, 10:07 PM
  #1535
rccarracer's Avatar
Anyone here got a 414X with original box and manual they are willing to sell?
All I can say is that I will pay a high price to take it off your hands...
PM to find out my offer....
rccarracer is offline
Old 11-14-2002, 10:28 PM
  #1536
icon's Avatar
hehe, i tried that. no one that i know of has one. i ended up settling for the original 414. they are very close in design.
icon is offline
Old 11-14-2002, 10:31 PM
  #1537
rccarracer's Avatar
Already have a 414, just want to complete my collection...
Old 11-14-2002, 10:38 PM
  #1538
icon's Avatar
LoL, i've looked everywhere . some people have them but are keeping them. my friend had one and i actually got to hold it, LoL. its a very nice car and yes it was that cool. wish i bought it from him back then .
icon is offline
Old 11-15-2002, 12:25 AM
  #1539
Vic
Vic's Avatar
Aurra,
Now I understand these spacers, I still have a question---What effects does it have on the car?
What was the problem again? You have too much on-power steering?[/COLOR]
The answer to your question is Yes but since I changed camber it is a hell of a lot better.
What do you think would front toe-in solve my problem?My set-up is:
Front:
Sway bar--no
Damper:--White spring-700oil
Toe out :-0.5
Camber: -1.5
Spacers for front arm: Front:3mm Rear:2mm
Damper position:very left hole
No spacers for front axles ortorque rod
Rear:
Sway bar--no
Damper:--Red spring-300oil
Toe in :+1.5
Camber: -0.5
Spacers for rear arm: Front:3mm Rear:2mm
Damper position:Middle hole
No spacers for rear axles
Thanx
Vic is offline
Old 11-15-2002, 02:16 AM
  #1540
imataquito's Avatar
reflekt.....
hm... i am just trying to tell u what i have come across....
better to be safe then sorry rite ....
heres what happened on my case
i placed the 3mm shims which comes on the car its self...
installed the rear Arm mount with 3mm front and 2 mm rear WITH everything on the car off.. except the arm mounts mounts
when i placed the rear bulkhead in and tighten it into place the bulkhead WILL not get into place ..... and if it does the plate will bend in a VERY odd angle ! making it tweaked and not flat if its placed on a flat surface......
i measured the shims ... with a caliper well.... they were EXACTLY the same size as the arm mounting blocks !!!
so i shaved some material off and thet solved the problem ...
well the shims i used is also the same one used on most locations like on the camber link mounts on the bulkhad and on suspension mounts ...
Old 11-15-2002, 02:43 AM
  #1541
rccarracer's Avatar
The easiest way to go about the spacers, is Tamiya'snew 5.5mm spacer set.
This is what they have been designed for...
Or use spacers that have a 5.5mm diameter....
Old 11-15-2002, 02:51 AM
  #1542
over gear's Avatar
Trader Rating: 18 (100%+)
Remove bulkhead bearings
How can i remove those bearings in the bulkhead? I saw a past post that someone used a wood dowel for the job?
The bearings are so tight that I don't think a piece of wood can get the bearings out. Any other suggestings?
FYI, it's a 414m2.
over gear is offline
Old 11-15-2002, 03:16 AM
  #1543
rccarracer's Avatar
I've never had to remove the bearings in the bulkhead, but have heard there is a light coating of glue to hold them in...
I have read the post about the wood dowel and that seems the best, but other people have said they have heated the bearings to loosen the glue....
Personally I'm not totally sure which to try.
Old 11-15-2002, 03:42 AM
  #1544
The light coating of glue holds the bearings nice and tight. If you tap them out make sure you put some glue in the bulkheads or the new bearings will slip out easily.
itchynads is offline
Old 11-15-2002, 07:29 AM
  #1545
Default Returning to R/C.
Hi guys. I've been out of on-road electric r/c for a little while, but I'm looking to get back in. I've decided on everything except a car so I'm soliciting your help. I realize that this is a forum for Tamiya enthusiast so I expect some bias. But that's ok, because I'm going to post the same question to the Xray forum, since my only other consideration (right now) is the Evo2.
Anyway, I'm looking for a car to race primarily in the stock class, with rubber tires on an asphalt parking lot road course. I want a complete car! I don't want to have to purchace swaybars, one way diffs etc. down the road (or at least keep upgrades to a minimum).
I have owned Tamiya cars in the past, so I'm familiar with Tamiya quality, and excellent building instructions. However, I've never owned one of the new generation of Tamiya cars (non tub chassis, carbon fiber with alumimun). This car 414M, II is a big departure from the Tamiya cars I remember.
Anyway, will you share with me the positive and negative aspects of the 414? How durable is this chassis? I remember Tamiya replacement parts being relatively expensive.
Other comments and suggestions?
Thanks.
DEACON is offline
