New Jaco Rubber Tires >
Old 08-05-2008, 02:32 PM
  #496
RedRocketRacing's Avatar
Originally Posted by Jack Rimer View Post
From what I heard about the race in Portland, the foam tires had no bite on the nitro cars either and they, too, wore out prematurely. That is very unusual.
Obviously the track has a huge impact on what works and what doesn't. These tires were developed by testing at the Florida state series- all asphalt tracks. The fact that they work on carpet is an added bonus. Until someone tries greens at that track, I think it is premature to pass judgement on the tires' performance.
From what I saw some of the nitros worked and some didn't. They at least had the chance to run what ever tire they liked. I personally didn't think there was a wear problem with the tires. More of a side bite issue, When I get back to SIR I am gonna try adding camber but it will be a tough comparassion to the Portland track. SIR grip is insane.
Being more of a carpet racer, I an anxious to try them on the rug.
RedRocket
RedRocketRacing is offline
Old 08-05-2008, 06:34 PM
  #497
Originally Posted by TeamButter View Post
When people say these tires are slower in their opinion they are referring to tenths of second per lap which MAY add up to 3-4 seconds during an entire race. I can guarantee that we are all responsible for more time loss than that on the track by clipping dots and boards.
I don't think anyone out there wants to be put at an immediate half lap disadvantage before the starting horn. That's why myself and others are working towards a solution for alternate tires. I don't want to put my racers at a loss right off the bat. At our track, on any given Saturday, .3 of a lap is the difference in being TQ, or being 6th.
So, with that in mind, can we get back on point, and get a workable solution for the Jaco Tires.
What I'm hearing is that you need more camber, anyone got a starting point suggestion. I tried 2.5deg, have others tried more? Less?
I've also heard running thicker shock oil is better. I'm currently running 35 weight oil, Corally shocks, stock pistons. I'm currently running 1.3 sway bars front and rear. Have others found going with stiffer sways to help.
Let's get a general group of setup suggestions on this board all consolidated so we can help each other.
thehobbyshop is offline
Old 08-05-2008, 06:51 PM
  #498
Trader Rating: 18 (100%+)
change the inserts and these tires would be dailed. i personally think they are to flat which requires you to make your car roll more than you have with previous cs or sorex etc, tires. but wear on these tires are like slim to none, good rubber, but i think w.e inserts the jaco blues have is a no gooder.. i hope Jack will be bringing out a new bash out with a improvement (of the inserts)
Roberto Falcon is offline
Old 08-05-2008, 10:09 PM
  #499
THeGame's Avatar
What are you talking about What is there to improve there is nothing wrong with the tire.!! It's the setup...
thehobbyshop you have PM...
THeGame is offline
Old 08-05-2008, 10:59 PM
  #500
RaceAce701's Avatar
Trader Rating: 86 (99%+)
Originally Posted by or8ital View Post
If you think about it though the statement is kind of false. I drive inconsistently every run. If we are talking a .3 second per lap difference between tires on average then it is a real 7 seconds (on our track). Hard to explain but we are talking averages here. We aren't saying .3 seconds per lap slower on one particular run, on average .3 seconds slower.
I will give you setup, I won't give you that driving makes up for it. Im consistently inconsistent
i understand ik was just trying 2 make the point that pople like 2 complain alot insted of trying new things
RaceAce701 is offline
Old 08-06-2008, 08:34 AM
  #501
TeamButter's Avatar
I agree with what you are saying, however very few clubs or "big events" use an open tire. Perhaps I should have been more clear or concise in my statement. IF this tire is being used as a handout, no one has an advantage but if you run a Jaco blue that lasts 5-8 runs competitively against say a Yokomo 138 G that lasts exactly 1.5 runs then you will have a problem. I think it is only fair to compare apples to apples.
I don't quite understand why it has been so hard for people to adapt to a new tire. Let us not forget that S-13's were the tire of choice in the beginning. Subsequent to that tire 100's of tires have come out some faster with no tire life some not faster but with an extended wear life. In the end the tire that was RELATIVELY fast and had long wear characteristics won out. We now have a similar situation. Hopefully there will be a resolution soon. All I can say is that Jaco is CONSTANTLY trying to improve the available product for its consumers.
Now back to the setup questions, as I posted before the camber link length seems to have a role in the wear of this tire. Shorter and more parallel links have worked best for me. However you may need to find that sweet spot on your car. Spring rates and oil Wt. have not had a profound effect on my particular car. I run 17 Lb front spring with a 14 Lb rear spring with 30 wt Xray oil and typically 2-3 holes open depending on the track. I always use sway bars and this may aid in limiting the sidewall roll.
TeamButter is offline
Old 08-06-2008, 09:55 AM
  #502
JamesArluck's Avatar
Trader Rating: 52 (100%+)
Jack,
YGPM about World GT tires.
-James
JamesArluck is offline
Old 08-06-2008, 11:25 AM
  #503
Default Private Message for Jack
Hi, Jack!
Just sent you a PM!
Thanks!
s-
Crashby is offline
Old 08-06-2008, 05:21 PM
  #504
I totally agree with you on handout tires. The Sweep 36's at Nationals weren't the best tire, but everybody was running them. However, Jack has a tire that is now in an open marketplace having to run against other manufacturers tires on the club racing level. And lets face it, selling a bunch of tires at next to no profit for major races isn't going to keep tire companies wanting to improve their products. So, they need to make up that money on the club racing level. Most of the tracks I've been to on the club level don't spec a tire, so the field is wide open to the fastest wins.
As to the shorter parallel links, that's a great example of what I'm trying to get everyone to place their input here so all of us can try things, and then give feedback to the manufacturer. It's interesting that you've found that spring weights and oils haven't had a big effect on the wear. Have you messed with different thickness sway bars?
Old 08-07-2008, 12:03 AM
  #505
syndr0me's Avatar
Trader Rating: 32 (100%+)
Finally got to run the blues on some high traction carpet tonight. They were awesome.
syndr0me is offline
Old 08-13-2008, 03:32 PM
  #506
fatbear's Avatar
Mr Jack Rimer,
you have a PM.
Thankyou
fatbear is offline
Old 08-13-2008, 11:46 PM
  #507
syndr0me's Avatar
Anybody having trouble with Prism rims being warped out of the package? I've had two sets now where one of the tires had a good wobble to it before ever seeing the track.
syndr0me is offline
Old 08-14-2008, 04:39 AM
  #508
Team EAM
Trader Rating: 79 (100%+)
I had some foam tires like that last year. What I found is that around the axle hole on the inside of the hex there was some left over flashing (SP?) from the mold. I just ran something flat with a wider blade around the inside of the hex and it was all good.
EA
EAMotorsports is offline
Old 08-14-2008, 06:17 AM
  #509
Looks like greens are the way to go at my local track. Seem to last pretty well also. You really need to keep an eye on the camber though.
Fred_B is offline
Old 08-16-2008, 01:03 AM
  #510
Guys
Are the Serpent Xceed tyres, jaco rubberz on the old dish wheel?
We dont get the Jaco Rubberz here in the uk.
Rich
richard baker is offline
