Old 07-25-2003, 10:59 PM   #106
GlennCauley is offline   Reply With Quote
Old 07-25-2003, 11:04 PM   #107
wheelmanST's Avatar
Send a message via AIM to wheelmanST
PUT me on record as saying its a shaft drive with the battery down the center and shaft down one side. And all 4 corners will share the same arms
i think he nailed it there....
or if not its a micro
wheelmanST is offline   Reply With Quote
Old 07-25-2003, 11:08 PM   #108
kenny's Avatar
I don't know why he edited his post but he said he personally spoke with an X-RAY team driver who told him this. I was kinda hoping it wasn't a micro...I just can't get exited about micro touring even if it is an X-RAY...
kenny is offline   Reply With Quote
Old 07-25-2003, 11:11 PM   #109
Originally posted by XCELL
If you play the clip for the preview, at the top of the box on the bar at the end it has the word micro.
Check it again. That is "Microsoft" at the end.
jbackslash is offline   Reply With Quote
Old 07-25-2003, 11:13 PM   #110
Randy Caster's Avatar
Trader Rating: 46 (100%+)
If the shaft wasn't down the center of the car, the front and rear diffs would spin opposite eachother. Front tires would go reverse, and the rears would go forward...
Old 07-26-2003, 03:22 AM   #111
You obviously have no idea how a shaft drive car works. Even if the shaft is off center it wouls have no bearing on what direction the wheels turn in, that is all dependent on what side of the diffs the gears are on. Rick
Rick Draper is offline   Reply With Quote
Old 07-26-2003, 03:43 AM   #112
rick draper - i think he was pointing out that the logistics of it would pretty much prevent you from putting the front diff gear on the left side of the shaft's pinion gear, so while technically you could have the shaft running down the left side with cells in the middle, to do so you would need the front diff to extend out practically to the wheels, which would kinda screw up the suspension, cause you wouldn't be able to have any hubs or arms etc
Trippin Freddy is offline   Reply With Quote
Old 07-26-2003, 04:02 AM   #113
davioh's Avatar
TL01's shaft isn't in the center
davioh is offline   Reply With Quote
Old 07-26-2003, 04:08 AM   #114
Yeah, but TL01's aren't fast either, so the design doesn't really work. they're also really wierd in terms of drivetrain.
Old 07-26-2003, 04:29 AM   #115
davioh's Avatar
when i got my TB01...my friends TL was almost as fast as it...but that was drag racing
Old 07-26-2003, 05:28 AM   #116
Carbon_Fibre3's Avatar
those were the good ol days, before you get serious.. lol .. it used to be the same at my house... come on lads ill race ya!... then i got into it.. so i dun go near the road wit my car..
anyways.. bring on the odd looking xray 12scale? lol.. im still hopeful
Carbon_Fibre3 is offline   Reply With Quote
Old 07-26-2003, 05:34 AM   #117
My guess would be a 1/12 pan car, as its the next most competitive racing class for EP..... yea 1/12 pan car
marzin is offline   Reply With Quote
Old 07-26-2003, 05:45 AM   #118
davioh's Avatar
i sometimes drive on the street with my evo....but not alot...downstairs is really dirty...so i guess i'll start fixing up my TB01...
Old 07-26-2003, 06:01 AM   #119
mistercrash's Avatar
R/C Tech Charter Subscriber
If this is a shaft driven 1/18 TC, I'm trying to figure out how much room would be left on the chassis for the batts and electronics. With a shaft in the middle, the motor would be on one side. With a shaft to one side, the motor would be in the middle. In the first case, the batt pack would be on the opposite side of the motor (very crappy balance) and in the second case, the batt would be weirdly placed surrounding the motor. Plus, most micro buffs run a minimum of six 2/3 cells in their car. A lot go with 8 cells and even ten. If there's only room in the car to run 4 cells, the micro buffs won't even bother buying one. Again, this is only if this thing is really a 1/18 TC, which I'm really starting to think it's not. There's already a lot of micro chassis manufacturers out there like Penguin and Motek for example, Motek coming out with a killer chassis for the micro HPI in August. I don't know if X-RAY will venture in the micro market, being that it's already very crowded IMHO.
mistercrash is offline   Reply With Quote
Old 07-26-2003, 06:11 AM   #120
davioh's Avatar
maybe a 4 cell shaft 1/12! it's new!
Is there a secret to gluing tires? teeforb Nitro Off-Road 44 06-02-2015 04:38 AM
Need help in top secret shell tofushop193 Painting, Designs, Graphics and Photography 0 03-24-2007 01:25 PM
What's the secret to soldering? Quinton Electric On-Road 30 01-08-2007 11:46 PM
Secret XXX-4G+ Mods Driver1 Electric Off-Road 3 03-22-2005 07:24 AM
