Old 04-22-2008, 01:36 PM   #16
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Originally Posted by gdcopbdcop View Post
over charging your lipo packs is a big no no. it doesnt give you any additional run time, or better voltage. what over charging does do is shorten the life of the battery, and could be very dangerous. it could cause the battery to fail, would would then cause it to cath on fire.
Yeah this isnt over charging a lipo....its getting it warm and peaking at 8.4 volts....and they are faster that way. A warm lipo is faster then a room temp lipo from everything that I have heard and seen....they are not over charged they are just warmer then normal.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 04-22-2008, 01:47 PM   #17
revo61's Avatar
Trader Rating: 18 (95%+)
Remind me to pit far away from you!
revo61 is offline   Reply With Quote
Old 04-22-2008, 01:51 PM   #18
Kevin K's Avatar
Funny thats not the first time I have heard that before....
Old 04-22-2008, 02:37 PM   #19
RCGaryK's Avatar
Kevin, you can't think of LiPo Charging like you do NiMH. Charging at a higher rate will slightly shorten the charge time at a cost of pack-life. HOWEVER, unlike a NiMH charger, as a LiPo pack gets close to "peaking" the charger reduces the amperage output gradually. This increases capacity while preventing the pack from exceeding the voltage. A LiPo also doesn't get warm while charging UNLESS it's about to go BOOM! If you want to pre-heat your packs ahead of time the charger will not be the source of what you're looking to do. You'll need to use a heating pad or covering iron or some other method. I've used the Losi 1-5 Cell LiPo charger for awhile and like it, and I've also used the Orion Carbon Advantage and the LRP Pulsar 3. I like the Losi because it'll also charge my 3-cell plane packs while my Orion won't (can't remember if the LRP does or not), plus the Losi has the balance ports too.
RCGaryK is offline   Reply With Quote
Old 04-22-2008, 03:01 PM   #20
revo61's Avatar
I have never heard of preheating packs. I would be to scare of this happening: http://www.youtube.com/watch?v=Gboge17PNBk
If you wanna try it, do it outside and have the fire department on speed dial.
Old 04-22-2008, 03:10 PM   #21
RCGaryK's Avatar
As long as you don't overheat them you "should" be ok. I warmed mine a little at the Nats and they did seem a little peppier
Old 04-22-2008, 05:48 PM   #22
picco007's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Thanks....that looks like what I will be hunting down.
Kevin, the reason why I picked the 610C is because of the internal balancer. I have the orion avionics charger and the balancer and the 610C is approx the same size without the extra balancer. Here is a couple of pics of my buddies 610C black edition Enjoy your new charger! When you get it.
EA Motorsports
picco007 is offline   Reply With Quote
Old 04-22-2008, 10:38 PM   #23
bvoltz's Avatar
Trader Rating: 44 (100%+)
Sorry to tell you, warming your LIPOs does help the preformance of the battery, but this is not need for club racing unless you are looking for the little extra.... The temp of warming them up is around 130 F... There are many posts here on RC Tech on this topic... You do not need the fire department on speed dial... Also it is STRONLY recommend that you put your LIPOs in a sack or something when charging no matter your way of charging, because it protects when something goes wrong...
Wheeling an Xray T4 and T4 14 using a Ko Propo, powered by EA motors and Speed Passion Speedo, paid for by my wife.
Digi3Dworks - 3D printing for the medical Field.
bvoltz is offline   Reply With Quote
Old 04-23-2008, 04:45 AM   #24
revo61's Avatar
Since I live in Florida, I don't worry about it in the summer. The pack will be at 100 on its own.
Old 04-23-2008, 08:26 AM   #25
Kevin K's Avatar
Thanks....I got mine on order...does it come with the balancer plug setup or do you need to order that on its own?
Old 04-23-2008, 09:14 PM   #26
picco007's Avatar
Kevin,
It comes with a circuit board that has 2-5S balancing ports. You can plug in Thunderpower balancing plugs and the SMC balancing plug too. I have an orion 3600 that I am making my own balancing plug (like my buddies pictures above) and I will make one for the SMC battery too.
EA Motorsports
Old 04-24-2008, 06:20 AM   #27
Kevin K's Avatar
Thanks for all the help.....
Old 05-13-2008, 03:24 PM   #28
picco007's Avatar
Kevin, did you get your charger? Let me know how you like it.
EA Motorsports
Old 10-04-2008, 08:48 PM   #29
Default thunder power
hello guys just got my thunder power lipo don't quite unsderstand how to charge my lipo, when i try charging it my lipo doesn't get warm at all and the amps are going down before it finishes charging, is that normal? Any help or pointers on how to safely charge lipo on thunder power would graetly appreciated, thanks in advance.....
civicsi is offline   Reply With Quote
Old 10-04-2008, 09:06 PM   #30
Trips's Avatar
Trader Rating: 16 (100%+)
That's entirely normal. A LiPO charger will use a Constant Current/Constant Voltage charge program. The first part of the charge is at a constant current until the pack reaches 8.4 volts, then it tapers off the current maintaining 8.4 volts (that's the constant voltage part) until it decides the pack is full.
LiPo's don't usually get warm on the charger under normal conditions like NUMH cells do.
MARSHAL!!
Trips is offline   Reply With Quote
LiPo: Charger and Battery Question Czolgosz Electric Off-Road 18 10-30-2008 09:09 PM
tt01/lipo/esc/charger/question FortySix Singapore R/C Racers 0 05-01-2008 07:03 AM
oh no! another lipo charger question jedsled Radio and Electronics 2 03-08-2008 06:42 PM
Lipo charger/pack question!! n3rd420 Rookie Zone 0 05-22-2006 12:39 PM
LiPo Charger question chumanji Electric On-Road 13 02-14-2006 10:22 AM
