Old 06-03-2010, 03:31 AM   #14956
this is my setup for the Tekin and SP13.5 V3
the motor is 70 DegreesC after 7 mins
and it seams quick
What do you think of it and could i give the motor some more ?? and if so where ??
our track is fast and flowing with a 70m straight and a fast lead onto it
FDR 6.9
motor timing fixed 10 degrees endball
Throttle profile 5
neutral width 10
brake 100%
Timing boost MAX
Turbo boost 10
turbo delay 0.6
Start 6,xxx (this was at 4,xxx but i thought it was a bit soft)
end 12,xxx
Let me know what you think
sidecarphil1 is offline   Reply With Quote
Old 06-03-2010, 04:31 AM   #14957
tmkhaw's Avatar
Send a message via MSN to tmkhaw
Hi guys,
I have been reading this really long thread for about 3 weeks and for it being one of the most active thread on rctech, there is really a lot read and search. I have recently started playing EP (been racing nitro offroad) and have bought and built an F104Pro. I have been very conservative on my EP spending and have been using loaners (ESC and motor) until now.
However, I entered my first EP race last weekend and qualified in B and managed to get 5th spot. I am starting to like EP onroad and would like to get into more serious racing.
I just bought 1 TP 17.5 and am looking for a new ESC. I have narrowed my choices down to either Tekin RS or RS Pro or SP GT 2.1. I do hope that i can also use this ESC on EP buggies as well. So, I am looking for a good universal ESC.
Any opinion, settings or help will be greatly appreciated. Thank you very much and keep up the great advices.
Below is the only post i found on F104 in this thread dating back to March.
Originally Posted by aussierevo View Post
I'm running a Tekin 21.5T in a F104 pro with the following settings;
Start RPM 2727
End RPM 10502
Timing Boost 40
Turbo Boost 10
Throttle Profile 4
Tubo Ramp 2
Delay 0.3
Neutral Width 5
Rollout 81mm
Track is medium to large free flowing track. Currently motor after 5min run is 122 degress F after each run.
I feel the car is very sluggish in the infield. With all the reading I'm doing, and if I understand it right, am I correct to lower my Timing Boost to say 20 and up the turbo Boost to solve this feeling
If so, what would be a good starting point for these settings, without getting the motor too hot and not sacificing straight line speed. I understand I should be aiming for around 135-145 as a good guide.
Any information would be appreciated.
tmkhaw is offline   Reply With Quote
Old 06-03-2010, 04:51 AM   #14958
hanulec's Avatar
Trader Rating: 27 (100%+)
It sounds like your close based upon other people I know running that motor.
Increase your end rpm - try from 18k to 23k all with a start around 5k. Also, try gearing up and down one tooth. One last thing -- maybe work to try less Turbo delay.
and it seams quick
FDR 6.9
Throttle profile 5
neutral width 10
brake 100%
Timing boost MAX
Turbo boost 10
turbo delay 0.6
end 12,xxx
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-03-2010, 06:21 AM   #14959
Skitee's Avatar
I think the wider rpm range will drop the motor temp slightly and just one more thing, if your track is fast and flowing then you shouldn't need to set your throttle profile to 5. You may see another small drop in temp by going to TP 3 or 4.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 06-03-2010, 07:12 AM   #14960
M-Technic's Avatar
Trader Rating: 15 (100%+)
and it seams quick
FDR 6.9
Throttle profile 5
neutral width 10
brake 100%
Timing boost MAX
Turbo boost 10
turbo delay 0.6
end 12,xxx
Start: 5,xxx
End: 20,xxx
Turbo delay: 0.2
You will then probably need to adjust your gearing a little bit.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 06-03-2010, 07:40 AM   #14961
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by tmkhaw View Post
Hi guys,
It is easy enough to find power for the F-104 and 2S 21.5
This is what we run locally with Tekin RS Redline Combo v203
Break.s-65
Throttle.p-3
Push-O
Boost-50
H-11000
L-44XX
Turbo-0
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-03-2010, 03:40 PM   #14962
Default Rs Pro power cap question
The power cap on my rs pro exploded a week ago so I bought the Tekin power cap which is labelled - G11 POWER CAP, 1000uf 16V. This power cap is larger than the original that came with my rs pro. My question is this cap ok to use with my rs ?????
XRAY T4 Hobbywing V3 Sanwa
FLAT OUT is offline   Reply With Quote
Old 06-03-2010, 05:50 PM   #14963
Krio's Avatar
Trader Rating: 150 (99%+)
Yes.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 06-03-2010, 06:50 PM   #14964
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
yep, i use that cap on all my RS's, and it has been specifically recommended by Tekin here on this thread.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 06-03-2010, 07:14 PM   #14965
RCknight's Avatar
Default Anyone know if Tekin is going to release....
a RS version that does not have timing for VTA? Sucks I just get one and my local track will ban them this fall.
RCknight is offline   Reply With Quote
Old 06-03-2010, 08:29 PM   #14966
can anyone give me some input on changing from duo1 [middle hole timing] 17.5 to a novak ballistic 17.5? i really like the setup i was using but i think i read the novak has more timing in the motor. if i was running 50 boost and 10 turbo what should i change them to? thanks
franc furter is offline   Reply With Quote
Old 06-03-2010, 08:31 PM   #14967
bukil's Avatar
Trader Rating: 39 (100%+)
I second that. When is the next firmware going to be released? I need something new to play with .
bukil is offline   Reply With Quote
Old 06-03-2010, 08:54 PM   #14968
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
what version did you use,if you like to go fast don't run the rcgt/vta,if they allow you to use a tekin and is honor system and don't tech go back to version 183
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-03-2010, 11:04 PM   #14969
Trader Rating: 17 (100%+)
Send a message via AIM to DJGonzo69
Default v208 Software
Does anyone know when the v208 software will be available?
|XRAY|RCAmerica|Hobbywing|KO PROPO|Team Scream Motors|Gonzo PaintWorX|
DJGonzo69 is offline   Reply With Quote
Old 06-03-2010, 11:14 PM   #14970
Just bought a tekin 13.5 system from my car and have a few questions. Do it come with a cap? And why is this needed?
immrwright7 is offline   Reply With Quote
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
