Old 05-31-2010, 01:56 AM   #14896
ShadowAu's Avatar
Originally Posted by JR007 View Post
Dual mode is sensored to stat off, and sensorless when it's rolling. It doesn't use any dynamic timing, but does still have esc timing if you want.
Dual Mode is almost always faster for lower turn motors, not to mention it's a hell of a lot easier to set up without all the other guff to worry about.
So at what number of turns would you use dual mode over sensored?
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 05-31-2010, 04:32 AM   #14897
Usually around 10.5 to 8.5. Depending on the car, the track, and the style of driving. It really does feel completely different, and worth having a try
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 05-31-2010, 05:25 AM   #14898
Dual mode for mod is a lot safer than playing around with timing boost and turbo with a "mod" motor in sensored mode. I've played around with both with a Redline 6.5 and the Dual Mode is a lot easier to drive. My 6.5 on sensored mode with timing boost and turbo was insane. And yes, I did manage to get it setup without overheating the motor and ESC (temping every minute instead of every 2 minutes) but it's not something I'd want to race with all the time. I was using it on a really big track that's more used for Nitro cars than electric. The punch in sensored mode was noticeably more than on dual mode and the turbo helped the top speed.
spongerX is offline   Reply With Quote
Old 05-31-2010, 08:46 AM   #14899
hpisims's Avatar
Originally Posted by kid TT-01 View Post
36mm rollout
50 Boost
15 Turbo
Start 3200
End 9000
.2 Delay
Thanks I appreciate the help.
J.SIMS
Team Associated TC6-Viper R/C Solutions-Sweep Racing-Fullthrottle Motorsports-APH
www.speedybillsrc.com
www.ovrccc.com
hpisims is offline   Reply With Quote
Old 05-31-2010, 01:27 PM   #14900
We have both a boosted and non-boosted 17.5 class running at our local track and I'm debating which of the 2 I am going to run this coming season. I'm wondering if I choose to go with the non-boosted class running V200 software should I run in dual mode or sensored only?
Old 05-31-2010, 02:37 PM   #14901
DaveW's Avatar
How do you guys plan on enforcing the non boosted class? Is it going to be a tech type thing where everyones RS will be checked with a laptop?
DaveW is offline   Reply With Quote
Old 05-31-2010, 03:04 PM   #14902
there is a setting coming out with the next update with a flashing LED sequence to prove the speedo is in "stock" mode
sidecarphil1 is offline   Reply With Quote
Old 05-31-2010, 06:33 PM   #14903
DaveW's Avatar
Originally Posted by 20 SMOKE View Post
for both, hit the calculate rpm and go to the next lower number under the 5k and this will help smooth it out if it is still punchy go up 1k on the endrpm
If either the delay, or the fact i am not at WOT keep me out of boost, then how is adjusting the start and end RPM going to affect the punchiness i referred to earlier? Isnt that what the throttle profile adjustment is for?
Old 05-31-2010, 06:36 PM   #14904
DaveW's Avatar
Ah, thanx for the info Sidecar...
Old 05-31-2010, 07:05 PM   #14905
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
timing boost and motor timing are added together through the rpm range you pick,moving it up and down less es the amount of timing every 1krpm and smooths out the feel,and you don't sacrifice speed
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 05-31-2010, 08:03 PM   #14906
lupin_au's Avatar
Send a message via MSN to lupin_au
Ok need a little advice on getting the best out of my set up.
The setup sheet for the car is here.
http://forum.teamxray.com/xform/inde...4&setup=t2_007
Im running a redline 17.5 and RS Pro.
Basic settings are
Drag brake 0
Brake 100
No push
Timing at 10
Boost at 15.
Throttle profile 3.
I have been seeing quite decent temps. Around the 50c mark but wonder just how much further I can push things. To help I have also included a layout of the track.
As you can see we have quite a long straight and only a few places where the car isnt at 100% throttle.
Any help to get me onto no1 position would be a big help (currently 2nd)
Exotek T2R | Schumacher Mission | M05 Mini | RC18R | X-Ray T2-007 EU | Tekin | Sprektrum | EDS
http://www.westcoastrccarracing.asn.au/
http://www.lupinzblog.com/
lupin_au is offline   Reply With Quote
Old 05-31-2010, 08:51 PM   #14907
20 SMOKE's Avatar
need the hole esc setup
Jamie W
Old 05-31-2010, 09:31 PM   #14908
Change you car to a Hot Bodies
Sorry, couldn't resist.
Old 05-31-2010, 09:51 PM   #14909
lupin_au's Avatar
I'll grab it when I get home. I thought I had a copy with me but cant find it.
Old 06-01-2010, 03:09 AM   #14910
lupin_au's Avatar
I figure a screen shot is the easy way, as its actually nowhere near where I thought it was at earlier.
My thoughts are to lower the end RPM to around 9000 or so, and increase the boost to max. But not sure if I'm on the right track in doing that.
Currently my best lap time is a 18.637s I would really like to see that drop to a 17 something if possible.
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
Sensored vs. Sensorless lemansracer Electric On-Road 71 02-14-2009 03:19 AM
New Tekin Redline Sensored Motors are Roar Legal! Randy_Pike Electric On-Road 3 08-05-2008 02:08 AM
Tekin Redline Sensored 10.5 HUCKMAN Electric On-Road 6 07-15-2008 08:50 PM
sensored vs sensorless bprocket Rookie Zone 5 05-16-2008 09:38 AM
Tags
v203, vegas 2.0
